Audio keeps going away at DVinfo.net
Old November 20th, 2008, 05:33 PM   #1
Hi.
I am trying to edit some footage in Vegas Pro 8 and my audio works good one minute and then stops the next. I have not clicked anything to turn audio off. I skip through my footage and it just stops playing. The footage still playes but I get no audio.
I am editing my usual footage from my camcorder and never had this problem before.
Any ideas on how to fix this?.
Thanks guys.
Matthew Ewing is offline   Reply With Quote
Old November 20th, 2008, 05:40 PM   #2
First, bring up the mixer, so you can see if you are getting a read as you play the clip or timeline.
I noted that I had trouble with earlier versions in XP with a playing clips in the tirmmer... they played much lower than on the timeline. I am now editing in Vista, and don't seem to have the problem. Might well be a setting I missed there.
Is it also possible you have the levels reduced on the time line when you start out, or that you have a volume envelope established, that reduces the sound. You could possibly have the envelope selected and have dragged it down by mistake. You could open a new audio track and drag your audio to that track, and see if that makes a difference.
Chris J. Barcellos
Old November 20th, 2008, 06:04 PM   #3
I brought up the Audio preview mixer and I get no signal at all. All the volumes are turned up and nothing. If I exit Vegas and then go back into my footage again, the audio works then shuts off if I start to edit or move my timeline selecter along the screen.
I am using Vista Ultimate 64 bit and have had no issues at all, until today. I checked my origanal footage in windows media player and Nero and the audio is fine. Vegas is causing the problem.
Old November 20th, 2008, 06:50 PM   #4
just a thought. Press the "B" button on the keyboard-that's the master audio and see if there's an envelope hanging around there. It happens every now and then when fingers go to fast and we hit a button without realizing it. B for the master track and V give and envelope and it might be there is a point there and it's set to inf.
Don
Old November 20th, 2008, 06:56 PM   #5
Just tried that and one part of my footage had audio and then it also stopped working.
This is so strange a problem. This is literally the first time Vegas has caused any bother.
Old November 20th, 2008, 09:09 PM   #6
if you are using XP, try loading a video/audio codec pack for xp, I would, after that, uninstall vegas and reinstall. it only takes a few minutes. Vegas does act up sometimes, seems for no reason, also go into control panel,system,device manager, see if there is a conflict,
Hugh Mobley is offline   Reply
