Short project needs image zooms at DVinfo.net
Old October 28th, 2008, 10:55 AM   #1
Since the editor is not available for weeks I have to do an edit...Oh-O! Not very slick at using Vegas but need to give it a go. I need to do this in Vegas Pro 8c...
A client wants to introduce 4 staff in video.
BG will be in motion - I can handle that.
There will be a title and company logo - can do. This is the bit I am stuck on....
The four will all be small static images on the top of frame. In sequence and from the left they will zoom out to full 720 x 576 PAL size and say their thing in full motion, then zoom back to their original position up the top of frame where they are again static. Once each is back in position, the next image zooms out to full frame, says their thing then zooms back into position.
I would be really grateful if you could show me how to do this on a tute of a veg please.
TIA
Geoff Jak is offline   Reply With Quote
Old October 28th, 2008, 12:34 PM   #2
Sponsor: JET DV
You can put the images on separate tracks and then use Track Motion and Keyframes to control creating the PIPs and resizing the images as needed. For more details, take a look at the first four issues of my newsletters.
Old October 30th, 2008, 06:43 PM   #3
Thx Ed
I'm still stumped but thanks anyway
Old October 31st, 2008, 06:35 AM   #4
Sponsor: JET DV
Ok, take a look at those newsletters and I think it will make sense but here's a short review:
The one you bring up front will always need to be on the top-most track, so you can't just place them all on 4 tracks and do it. Here's an option for you:
Track 2: 1st image using Track Motion to place it in the proper place/size.
Track 3: 2nd image using Track Motion to place it in the proper place/size.
Track 4: 3rd image using Track Motion to place it in the proper place/size.
Track 5: 4th image using Track Motion to place it in the proper place/size.
Now do all the main work on Track 1:
All 4 images will be on this track. Do it like this:
11111111111111222222222222222233333333333344444444444444
k1 k2k3 k4k5k6 k7k8 k9k10k11
(don't know how the above will come out)
First keyframe (k1) will be the first image in the proper position. The second keyframe will be exactly the same. The third keyframe would be the first image full screen. The fourth would also be full screen. The fifth would then return back to the original location same as keyframe 1.
Now you'll switch to the second image. Keyframe 6 would be used to put the second image into the proper PIP location. Keyframe 7 would be the same as 6. Keyframes 8 and 9 would be full size. Then you go back to the image 2 location with keyframe 10 (same as keyframe 6).
Repeat for the other two images and you're done.
Edward Troxel is offline   Reply
