Static at DVinfo.net
Old October 2nd, 2008, 03:37 PM   #1
Static
I just put a Vegas 7 computer in a secondary studio, recorded several audio tracks, suddenly on playback it is all static..any ideas? Thanks
Michael Best is offline   Reply With Quote
Old October 2nd, 2008, 04:05 PM   #2
how did you load it in? if from a camera or deck it might be a loose connection somewhere. Vegas itself should not be the root of the static. the only time I had that was using a deck that had a loose FW connection.
If you simply copied the file from a HDD then it might be something in the original file OR the OS that isn't playing well with Vegas.
Don
Old October 2nd, 2008, 04:15 PM   #3
This does not involve a camera at all, I am recording some instruments into the audio tracks via I/O, that is all working fine, it even played back fine a couple times but now all the tracks have static, the static will stop for second and then come back in.
Old October 2nd, 2008, 04:18 PM   #4
AH, OK then. Well maybe try this. Go to the track header and turn off the audio presets that are there. Try to play - if no static then turn them back on 1 at a time see if and when it comes back.
If that doesn't do it you migh want to re-install Vegas. Sometimes that'll do it.
Don
Don Bloom is offline   Reply
