Mixing 24 fps Animation and Live action - then rendering... at DVinfo.net
Old September 15th, 2008, 03:49 PM   #1
I recently took some footage off of a commerical DVD using AVS DVD-to-go. It creates AVI files of the clips you select. BTW the live action footage looks fines if you play in Windows media Player as an AVI.
I am re-editing this footage with NEW speical effects created as .png images and importing them as a string of images.
I am using Veags 7 and have the properties of the timeline set to 24p NTSC DVD to take advantage of the 24 fps images. Interlace is none as this is progressive.
When I render all of this together (DVDA 24p NTSC video stream) I get good results except that some of the live action footage ripped from the DVD is jerky in spots - as though there is a problem with the 24p timeline. If I change the timeline to interlace 29.97 fps then the animation clips (images) start having problems - some doulbe images etc. as it tries to conform to the 29.97 fps output.
Is there a better way to combine these different formats? A properties setting that is more forgiving?
Thanks as always.
Phil Hamilton
hamiltonp@sbcglobal.net
Dallas, Texas
" I'm shocked, shocked to find that gambling is going on in here! ..."
Phil Hamilton is offline   Reply
