Slideshow in a PAL Widescreen project at DVinfo.net
Old September 13th, 2008, 03:09 AM   #1
In a 720x576 Widescreen project, in preprocessing, should I crop my stills images to:
787x576 (accounts for PAL DV pixel aspect ratio of 1.0926)
or
1049x576 (accounts for PAL DV WS pixel aspect ratio of 1.4568)
Dan Bridges is offline   Reply With Quote
Old September 13th, 2008, 03:56 AM   #2
Dan
I think there may be some graphics packages where you can possibly specify the pixel aspect ratio so you could specify 720x576 at PAR of 1.4568. I use Serif PhotoPlus which doesn't have that facility so I always use 1049x576 - works fine.
Of course , there's nothing to stop you using 720x576 and having a border either side.
Ian
Ian Briscoe is offline   Reply With Quote
Old September 13th, 2008, 04:21 AM   #3
Dont crop them at all. Just place them in the project in their native aspect and resolution. In Vegas then click on the Pan/Crop icon, right click and select "Match output aspect". Let vegas take care of it and it does a great job.
My project would either be Pal DV widescreen or HDV 50i.
mintyslippers.com
Danny O'Neill is offline   Reply With Quote
Old September 13th, 2008, 08:14 AM   #4
That's a good point. Using Pan/Ctop will also let you experiment with cropping without having to go back to your graphics application.
Ian
