titling question at DVinfo.net
Old September 7th, 2008, 05:32 PM   #1
titling question
When using the sony credit roll in MEDIA GENERATOR for titling, can you alter the speed that the title graphic enters the frame?
Old September 7th, 2008, 05:40 PM   #2
If you slow down the roll speed by adjusting the "Length" time in the Credit Roll window, this makes the total event time longer.
If you only want to slow down the initial title, create it as a standalone event and use Pan/Crop to "roll" it up the screen.
Old September 7th, 2008, 09:21 PM   #3
If you want to slow down the overall speed of the "credit roll" then set a higher value in the "Length"input box.
Then extend the event on the time line to the new value. see pic below:
http://www.dvinfo.net/conf/members/b...ated-media.jpg
If you want to alter the speed that the title "enters" the frame then I would use a velocity envelope.
Björn Rehder is offline   Reply
