1440x1080x32 what does the 32 mean ?? at DVinfo.net
Old August 22nd, 2008, 12:28 AM   #1
this is the PAL XH A1.
in Vegas clip properties it shows this per clip.
what is that 32 at the end?
i googled it and no luck.
thanks
George Zabetas is offline   Reply With Quote
Old August 22nd, 2008, 01:58 AM   #2
That's the bit count for the color sampling. 32bits in total.
Old August 22nd, 2008, 03:22 AM   #3
thanks jack, but isn't it really 8bits?
Old August 22nd, 2008, 03:54 AM   #4
that means you are using an alpha channel (4x8 RGB+a).
Since you cannot divide 32 by 3 , it is likely the case, but you could have 30bit RGB with 10 bit for each color.
Old August 22nd, 2008, 06:44 AM   #5
Moved from Canon XL to Vegas.
Old August 22nd, 2008, 06:46 AM   #6
Images: 10
It means you are using an alpha channel, 8 bits per channelx4=32.
When there is no alpha channel, it reads 24.
Old August 22nd, 2008, 11:58 PM   #7
regarding the alpha channel, is this something inherent in the HDV stream? because i have not used anything. this is just clicking on the clips in explorer and reading their properties underneath. no processing.
thanks again
