Audio channels volume controls at DVinfo.net
Old August 19th, 2008, 12:40 PM   #1
in Vegas, how do I display both, left and right, audio channels volume control, now I do have both wave graphs in sound track, but the only one volume for both,
I need to bring down right and bump up left channel (for example), men, I can't recall how's done,
Many thanks!
Old August 19th, 2008, 12:42 PM   #2
On the track header, you use the slider for left to right balance.
it'll show a pink (i think) line which shows where you change the balance.
I'm not sure how to display both tracks as 2 seperate streams though. I wouldn't mind knowing that myself.
Paul.
Round 2
GH5,FZ2000
Old August 19th, 2008, 12:57 PM   #3
split the track then use pan envelopes or the sliders on the track headers for Left and Right.
There are scripts out there to split the track OR you can copy and past the track to a new track then set 1 track to left channel only and the other to right channel only. You can do that by right clicking on the track and goto CHANNELS>. There is another menu there that will say BOTH, LEFT only, Right Only Combine and Swap. Choose your poison and you're all set.
Don
Old August 19th, 2008, 01:02 PM   #4
Don
How do i split the track ?
And where is "channels" ?
Thanks.
Paul.
Round 2
GH5,FZ2000
Old August 19th, 2008, 01:09 PM   #5
Found channels.
Paul.
Round 2
GH5,FZ2000
Old August 19th, 2008, 01:11 PM   #6
to split the track without a script, simply C&P the track to a new one then use channels to use LEFT on 1 and RiGHT on the other.
Don
Old August 19th, 2008, 01:14 PM   #7
Ah yes i see.
Thanks Don.
Paul.
Round 2
GH5,FZ2000
Old August 19th, 2008, 07:22 PM   #8
Don
Thanks Don, that does the trick, can't believe there is no native Vegas option for that;
this is a second thing, after speed /duration control, that is easier to do in Adobe, but that's probably it :)
Many thanks!
Old August 19th, 2008, 08:27 PM   #9
Edward Troxel has a free one on his site.
You may need to be logged in to be able to get it but it's quick, painless and spam-free.
Old August 20th, 2008, 12:04 AM   #10
Another one here:
Sony Creative Software - Forums - Vegas Pro - Scripting Messages
French Vegas Addict.
http://www.cameravideo.net/forum/son...dvd-architect/
Gilles Pialat is offline   Reply With Quote
Old August 20th, 2008, 06:52 AM   #11
Originally Posted by Gilles Pialat View Post
I've downloaded these scrpits, now what do i do with them ?
How do i install them ?
Thanks.
Paul.
Round 2
GH5,FZ2000
Old August 20th, 2008, 06:53 AM   #12
Sponsor: JET DV
Buba, splitting tracks is a very simple process but does take a few steps to accomplish. That's one reason why I, and others, have written the scripts to make the process a one button click.
As for velocity/duration, can you explain further? The process is pretty simple in Vegas so I'd like to hear your thoughts on that. Also, once again there may be scripts out there to simplify your needs even more.
Old August 20th, 2008, 06:57 AM   #13
Sponsor: JET DV
Paul, if you download mine from the link Mike provided, you simply place the file you download into Program Files\Sony\Vegas ???\Script Menu
It looks like the ones from Gilles would also go into the same location.
Plus, the two *big* scripts (Excalibur and Ultimate S) will both do this as well.
Old August 20th, 2008, 07:02 AM   #14
Ah yes, i sussed it .
Thanks Ed.
Paul.
Round 2
GH5,FZ2000
Paul Kellett is offline   Reply
