Vegas doesnt support .Mov? at DVinfo.net
Old August 9th, 2008, 07:32 AM   #1
Im trying to add a file in and its just lets the sound show up?
I have the 2005 edition.
Jim Stern is offline   Reply With Quote
Old August 9th, 2008, 09:16 AM   #2
I think this is a re-install quicktime solution. I have had this happen to me a couple of times. I don't know of any reason not to have the latest and greatest.
Harold
BhagaVideo.com
Harold Brown is offline   Reply With Quote
Old August 9th, 2008, 10:49 AM   #3
It may be you don't have the video codec needed to read the file. You can find out what codec was used with GSpot (http://www.headbands.com/gspot/).
Rob Wood is offline   Reply With Quote
Old August 10th, 2008, 08:23 AM   #4
Sponsor: VASST
Whenever just the audio or just the video shows up on the timeline, it is almost always a codec problem. You need to make sure you have the appropriate codec installed on your system for that file. Open the MOV file with the Quicktime player. In the Quicktime Movie Player select Window | Show Movie Inspector (Ctrl+I). In the Movie Inspector window look at the Format: parameter. This will tell you what codec is being used.
I have no idea what that means. The 2005 edition of what?
Just for the record, GSpot only handles AVI files so it will not report the codec in a MOV file. As stated above, this can be done right in the free Quicktime player. (Otherwise, GSpot is indispensable for debugging AVI files and should be in everyone's kit) ;-)
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old August 10th, 2008, 10:00 AM   #5
actually, GSpot has had an update to v2.7 which now includes MOV and WMV support... i tried it using a PhotoJPEG and MPEG-4 QuickTime; read them no problem.
tho it also says QT support isn't "fully complete" yet, so it may not work with the file Jim's having problems with... and yeh, definitely doing the CTRL-I thing is the best 1st step with a QuickTime codec issue.
Old August 10th, 2008, 11:15 AM   #6
Sponsor: VASST
Ahhh... I had tried the new GSpot but I didn't like it. I felt it actually gave me less information than before so I switched back. I forgot I was using the old version.
~jr
Old August 10th, 2008, 11:39 PM   #7
Be sure you installed the Authoring components for quicktime (it's default, now, but didn't used to be that way).
Not that it affects QT files much, but be sure you're ignoring 3rd party codecs, too.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline   Reply
