First attempt at Chromakeying at DVinfo.net
Old August 7th, 2008, 09:07 AM   #1
Hi all,
Well today I edit my first project that uses a green screen. So far I am toying around with the ChromaKey effect as well as the Color correction Secondary.
Lighting condition were excellent at the time of shoot and it is not a complicated shoot, just a newscast format, one camera in shifting from one anchor to the other in a closeup shot and the second camera is a wider static shot showing them both.
With the two effects mentionned above I am close to a something really nice. Of course the edges are bleeding here and there but I am tweaking the effects now.
Do you guys have any starter tips on how to handle green screen, a secret method maybe :)
Also I would need to have a white background behind them. I could I go to get that because right now when I apply the effects the BG turns black?
Thanks a bunch,
Phil
Phil Gosselin is offline   Reply With Quote
Old August 7th, 2008, 09:27 AM   #2
Keith Kolbo has an excellent tutorial called Using Chroma Key and Chroma Blur in Sony Vegas.
Old August 7th, 2008, 10:06 AM   #3
I did find it through Vasst and i must it is indeed excellent, thank you Keith.
I am pretty sure I will come back and add on this thread since I am far from being done. I still need to add texts, pictures etc..
Cheers
Phil
Old August 7th, 2008, 10:08 AM   #4
Sponsor: VASST
I second the vote on Keith's tutorial. It will really teach you what you need to know. In it, you will find that adding a Chroma Bur to the beginning of the FX chain really smooths out the key quite nicely.
Adding the white track should be as simple as placing that track below the one you are keying. This will allow the white to show through the keyed areas.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply
