no chapters imported to DVDA5 at DVinfo.net
Old August 4th, 2008, 10:00 AM   #1
Suddenly DVD Architect doesn't import/open mpeg2 files from vegas without chapters/markers??? what happened. those files were rendered in vegas with markers...
Marius Boruch is offline   Reply With Quote
Old August 4th, 2008, 11:02 AM   #2
Sponsor: VASST
For MPEG-2 files the markers aren't actually embedded. They are kept in a separate file with the same filename and the extension of .mpg.sfl (so myVideo.mpg generates myVideo.mpg.sfl). Make sure that this file exists and is in the same folder with the original mpg file.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old August 4th, 2008, 11:22 AM   #3
Same thing has happened to me, what John says is correct of course. If you move your project files, but not all the necessary ones, your markers won't follow.
Old August 4th, 2008, 11:42 AM   #4
yes, those files were created and were in the same folder; it was working OK and suddenly I experience problems
Old August 4th, 2008, 12:07 PM   #5
Try Saving As project to a brand new folder, maybe they are corrupted?
Old August 4th, 2008, 05:10 PM   #6
saving as project will not create sfl files - only render as will
Old August 4th, 2008, 08:47 PM   #7
Oh well, so much for that idea!
Old August 5th, 2008, 06:11 AM   #8
Sponsor: VASST
Ultimate S Pro has a function on the DVD tab that will rebuild the file for you. Just open the original project and it will create the .sfl file from your markers.
There is a 15-day fully functional free trial so you could download it and use it just for this purpose but it does a whole lot more so you should check it out. In the interest of "full disclosure" I am one of the authors of Ultimate S but it will solve your problem.
~jr
Old August 5th, 2008, 12:56 PM   #9
I'll vouch for Ultimate S, it is awesome...you can take anything that John says to the bank...I couldn't live without it.
