Rendering Filters at DVinfo.net
Old August 3rd, 2008, 12:40 AM   #1
Rendering Filters
I've noticed that some filters don't render as they look in the preview, they render less extreme. For instance Vitascene's defocus filter renders much less blurred than it looks on the preview. Also when I render film effects the grain, hairs, spots etc look much less extreme.
Anybody know why this might be?
www.springproductions.co.uk
Tony Spring is offline   Reply With Quote
Old August 3rd, 2008, 04:12 AM   #2
Is your preview window set to Best/Full?
Old August 3rd, 2008, 11:44 PM   #3
Old Boot
This is starting to "ring-a-bell"? What version, release and build of Vegas are you using?
Grazie
Old August 4th, 2008, 01:17 AM   #4
No I use preview/auto. When I render to new track the render looks very different.
Old August 4th, 2008, 01:18 AM   #5
Grazie
I'm using Pro 8b with Cineform intermediate files, renders are to Cineform too.
Old August 4th, 2008, 02:37 AM   #6
With that setting, I'd expect it to look different.
The resolution of the Preview window on preview/auto is half of what it is for best/full.
Look at the numbers in the bottom left corner of the preview window and you'll see what I mean.
I get the same "lower quality" effect if I'm previewing text.
At preview/auto, it looks soft and fuzzy.
At best/full, it's crisp and clear.
If you can't do a proper preview at the setting, do a RAM render of a short piece.
Old August 5th, 2008, 01:05 AM   #7
But if the render and the unrendered event are compared on the same timeline in the same preview window shouldn't they look exactly the same?
Old August 5th, 2008, 06:17 AM   #8
Sponsor: VASST
No, because one is an approximation of what the filter "might do" and the other is the exact result of what the filter "did" do. In the latter case the preview has the real result of the defocus so it doesn't have to approximate the FX. It's just approximating the resolution. Look at them both in Best (Full) mode. They should look the same.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old August 10th, 2008, 03:19 AM   #9
~jr
Thanks John & Mike. I understand now that "preview" is exactly that, but why do some filters render out as they look in the preview while others don't? I can't get Newblue film looks to render anything like it looks in the preview.
Old August 10th, 2008, 07:58 AM   #10
Sponsor: VASST
Preview is a trade-off of quality for frame rate. Some filters are light on the CPU and the preview doesn't have to sacrifice much quality to keep the frame rate up. Other filters are heavy on the CPU and so more quality is sacrificed in order to keep the frame rate acceptable. This will cause different filters to preview differently. Film Looks usually uses very CPU intensive processing so you may see more of a difference between Preview and Good or Best.
~jr
