can't play in trimmer window
sure i'm just missing something,
but i can't seem to get clips to play in the trimmer window. not the buttons in the window or spacebar seems to work. can someone set me straight? |
Sponsor: JET DV
Is everything else working? If the buttons in the trimmer window aren't working, that would be very odd - especially if everything else is working. At this point, the only suggestion I'd have would be to reinstall.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
yeah, everything else appears to be working.
odd. |
same problem...can't play in trimmer window
Hi,
I just noticed the same problem--I can't play in trimmer, although everything else seems to work. Did you find a solution? Thanks, NG |
#5 |
When the Show Video Monitor button in the Trimmer window is selected, video that you preview from the Vegas Explorer and Media Manager windows is played back in the Trimmer... There are several button selections in the trimmer you need to mess with... Took me a few minutes as well.
#6 |
Problem fixed: needed to upgrade build
Ignore my last post--I was running vegas 7 version c and needed to update to "e". Problem solved.
