Picture In Picture at DVinfo.net
Old June 16th, 2008, 12:05 PM   #1
Picture In Picture
Is there a way to place a picture in picture using Vegas Pro 8?
If there is, does anyone know a link to a tutorial?
Rich
Rich Nicholls is offline   Reply With Quote
Old June 16th, 2008, 12:18 PM   #2
I am not familiar with Vegas, but with any NLE I have ever used, I do the following:
(1) Place the two target layers of video directly on top of each other, being sure that the video to be shrunk is on the higher layer
(2) Select the higher layer video and go to it's properties
(3) Adjust the scale to a size that you see fit...in your case, perhaps 30% or so.
(4) Position the video to the proper location either by dragging it in the preview window, or manually changing the x and y coordinates
Hope this helps...
-JS
John Stakes is offline   Reply With Quote
Old June 16th, 2008, 12:42 PM   #3
John is correct with the way he said it. In Vegas, you'd want to use Pan/Crop (or Track Motion could work too) on the upper-most track (the one you want to make the smaller picture).
Andrew Kufahl is offline   Reply With Quote
Old June 16th, 2008, 12:44 PM   #4
Rich, take a look at Vol. 1, #2, 3 & 4 of Edward Troxel's newsletters as he gets into the details of PIP.
Old June 16th, 2008, 01:06 PM   #5
Sponsor: JET DV
Andrew, PIPs are actually much easier using Track Motion than Pan/Crop. While they both will work, I would recommend Track Motion first for creating PIPs.
Rich, as Mike said, check out those newsletters. They go into significant detail.
Old June 16th, 2008, 01:57 PM   #6
Look here.
http://www.youtube.com/watch?v=gkphFAZN-iI
Paul.
Round 2
GH5,FZ2000
Paul Kellett is offline   Reply
