SHOULD I INSTALL VEGAS 8 PRO yet or wait for upgrades...
Hello everyone,
I am brand new to Vegas. Just purchased VEGAS 8 PRO from Videoguys.com, & got a new Toshiba Satellite Laptop with 400Gig Hard Drive, 4 gig of Ram, & is pre-installed with VISTA SP-1. (64 bit) My question is this: do I have to wait for the 64 bit upgrade for VEGAS, or can I install now, and will it work on the above machine? Secondly, how many installs do I get with Sony Vegas? 1 or 2, or 3? Thanks very much Peter Vaughn Chicago, Illinois |
Wait
Vegas 8 Pro is a work in progress that suffers crashes on a regular basis. I'm in the process of transferring a feature to 7.0d to finish it.
Wait until 8.0c comes out, then wait until you start hearing positive things about it before installing. |
I don't have 64bit, but i do have vista sp-1 32bit, and vegas pro 8 has been nothing but solid for me, and i have also installed patches a & b when they were released.
Paul.
Round 2 GH5,FZ2000 |
#4 | |
What media and size (timeline length and complexity) are you working with? How much memory does your system have? What codecs do you primarily render to? All my crashes have happened on a DVC Pro HD timeline at 720P, rendering out to Cineform and DNX HD files... I'm really trying to track down this problem, as I am a huge Vegas promoter and don't want to see its reputation suffer needlessly... |
#5 |
Sponsor: JET DV
And I've been using Vegas Pro 8 for nearly a year and enjoying the benefits it gives me. One of the biggest benefits to me is the new scripting abilities where scripts can now stay active all the time. But there are other benefits as well.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#6 | |
i.e., if you have two desktops in different locations and a couple of laptops, you can install Vegas on all of them as long as you only use it on one at a time. After a certain number of installs, you will be required to contact Sony to verify you are still the licensed owner (I need to do this but keep forgetting so I can start using it on Vista 64) You also need to activate each installation online. If the target computer doesn't have internet access, Vegas provides a way to activate it using a different computer. |
#7 | |
Media size, all sizes, the most i've had on the timeline at one time was 115gb footage, from my EX1 and about 20gb from my small handheld cam, used for cutaways etc, which was then edited with multicam. I usually render to mpeg-2 for dvds (dvd-a), WMV for web stuff or Sony AVC for vimeo stuff. With my small handheld cam, Sony DCR-SR90, my pc renders in a bit more than real-time for mpeg-2. With the HD footage, about 2.5 times with effects for mpeg-2. My pc is quad core Q6600,(2.4ghz) with 4gb ram. Paul.
#8 |
Been running Vegas 8 on my Vista 64Bit Ultimate setup for a couple of months without any issues at all, no crashes thus far, rendering my HD footage from my Hg10 has been flawless, waiting patiently for the DVD Architech 5 free upgrade later this month as well as the free 64 Bit Vegas upgrade this fall....Go ahead and install you will be fine....
#9 |
OK, I will go ahead and install!!
Thanks David, and everyone for your input.
I will go ahead and install and get to work, & hopefully the crashes will be kept to a minimum. |
#10 | |
As evidenced by the posts here, the problems do seem to be a hit-or-miss affair. It probably depends on each users computer configuration, memory, etc. That's arguably one of the advantages Apple in general and FCP specifically has. Since they control exactly what goes into each Mac, these variables disappear, hence the stability of their OS and software. I still love Vegas, which I say as I type on my Mac. |
#11 |
To use your example above, how would Vegas know if you're using it on all the computers at the same time? Provided all 4 were activated online, then the internet connection disabled. So now all 4 computers are offline.
#12 |
Sponsor: JET DV
Hopefully your morality and knowledge of right and wrong would prevent you from abusing this policy. Otherwise, it might change to the disadvantage of us all.
#13 |
I understand where you're coming from. For me, I have 2 desktops, and 1 laptop that I carry with me on all trips. I may have different projects at the same time. If my wife is using one of the desktop, then I'll edit another project on the other desktop,....That's why I'm wondering.
Thanks, |
#14 | |
It states (emphasis added by me): Our licensing agreement permits you to install the software on as many machines as you own, as long as you are not running the programs at the same time. For instance, you can install the software on your home machine and on your laptop. You are not allowed to install the software on multiple machines if you are going to be using them simultaneously, such as in a home studio setting. If you are going to run the software concurrently on more than one machine, you would need to purchase a separate license for each computer. |
#15 |
Sponsor: JET DV
Norris, depends on what your wife is doing on that computer. If she's editing in Vegas, you're technically in violation as you and she are both running a copy at the same time. If she's doing something else and you're the only one editing, then it's fine as you're the only one running the program even though both machines are running.
