Peak Building taking too long... at DVinfo.net
Old June 1st, 2008, 02:49 PM   #1
Should peak building take 10+ minutes on a 60 minute HD MPEG? I have 3GBRAM with a Q6600 quad core.
I used to import 60-90 minute mpeg files (sd) and it would only take 2-3 minutes MAX...does HD make that much of a difference concerning peaks?
HVR-A1u,WCS-999,HVL-20DW2 w/diff,2xAudio-Technica Freeway 600,Flycam 3000,Vegas 7E
Jason Donaldson is offline   Reply With Quote
Old June 1st, 2008, 10:40 PM   #2
Slash Rules!
I'm not trying to be an ass here; this is a sincere question:
Do you NEED the peaks built every time you open the program? On my longer projects, I would just tell it cancel when it started trying to build the peaks, and start editing, only building the peaks when I was messing with sound-related stuff. Furthermore, you can make it build at any time with a keyboard command. When you do that, it should only build what's currently visible in your timeline.
Old June 2nd, 2008, 06:52 AM   #3
Sponsor: JET DV
I'm guessing it's totally file dependent. Files that require Vegas to use a slower reader would build more slowly than those that can use a faster reader.
Edward Troxel is offline   Reply
