DVDA colors & brightness changes when making DVD at DVinfo.net
Old May 21st, 2008, 08:17 AM   #1
When I make a DVD with DVDA 4.5 the colors change a bit and gets darker.
If I put the rendered DVD file on the timeline next to the rendered HDV file using Pro 8, they are identical. But when I make the DVD it turns out with with slight color change and darker. Does anybody have this problem?
Bob Magill is offline   Reply With Quote
Old May 22nd, 2008, 12:11 AM   #2
What is the source? What player are you using to view the content? Software or hardware?
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old May 22nd, 2008, 09:56 AM   #3
Spot, After reading your reply, I played the DVD on other players and discovered that the player I normally use connected to a Samsung DLP Wide screen 1080i TV actually plays darker than the other DVD players connected to the same TV. Thank you for your input. By the way, I have several of your Training DVD's that helped me learn Vegas editing.
Old May 22nd, 2008, 11:01 AM   #4
Originally Posted by Bob Magill View Post
...the player I normally use connected to a Samsung DLP Wide screen 1080i TV actually plays darker than the other DVD players connected to the same TV.
Bob, my guess is that this particular DVD player isn't adding setup (7.5 IRE) while the other ones are. This would explain why it's darker than the others.
The unfortunate part is that this feature (or lack thereof) is almost never docimented in the player specs :-(
Mike Kujbida is offline   Reply
