Sony Vegas, anybody using it? at DVinfo.net
Old May 8th, 2008, 09:01 AM   #1
Hello all, was in Circuit City yesterday and noticed two versions of Vegas soft.
I remember seeing it in Videographer's magazine and that it got some awards. Do any of you use it? How is the interface etc? I was also confused with different versions, CC has yellow box for $99 and platinum edition for $149. I also saw like 10 different versions on Ebay. Please, give me your feedback.
Thank you in advance, KC.
K.C. Kennedy is offline   Reply With Quote
Old May 8th, 2008, 09:14 AM   #2
Moved to our Sony Vegas forum.
Old May 8th, 2008, 09:26 AM   #3
Sponsor: JET DV
You'll find LOTS of people using Vegas now that the message has been moved to the Vegas forum. The versions you're seeing at Circuit City are the "Movie Studio" versions. These are basically "lite" versions but still have tremendous power and functionality. They are great for starting out editing. Once you decide you need more power, you can always upgrade to the pro version.
You'll also find tons of help here and many resources for Vegas throughout the web.
Here's a comparison of the three versions of Vegas: Movie Studio, Movie Studio Platinmum, and Pro:
http://www.sonycreativesoftware.com/vegaspro/compare
Old May 8th, 2008, 09:29 AM   #4
Thank you, Ed.
What's the top of the line version named then? I'll look out for that one.
Old May 8th, 2008, 09:30 AM   #5
Sony Vegas Pro 8 is the current top o line product.
Bill Mecca is offline   Reply With Quote
Old May 8th, 2008, 09:48 AM   #6
Holy Crack
$699 current price for it at CC site, does it really have $600 worth more bells and whistles than regular version?
Old May 8th, 2008, 09:51 AM   #7
Look around, you can get it much less expensively elsewhere.
Puttin the wet stuff on the red stuff!
Terry Esslinger is offline   Reply With Quote
Old May 8th, 2008, 10:01 AM   #8
Ebay has it for under 300, so what's the big difference between basic and pro versions?
Old May 8th, 2008, 10:14 AM   #9
See Ed's link for specifics, and lots of them.
Some of the basics that the Pro version opens up are unlimited tracks, built-in multicam, better monitoring, video scopes, and scripting.
The studio versions are a very inexpensive entry to a great editing environment. The pro version is well worth the price if you need its capabilities.
PS. beware pirated software on Ebay, and/or versions that don't include the excellent DVD-Architect. Good software is there too... Forum sponsors are good sources at good prices - I believe videoguys.com is currently running a Vegas special, but also check out B&H. Look for the link at the very upper right of any dvinfo.net page.
Old May 8th, 2008, 10:15 AM   #10
...way too many differences to mention between the pro and the home "lite" versions... check the sony site for the compare chart...but just one example is you have unlimited tracks in pro version and you are limited to just a handful of tracks in home version...i could not work with a limited track number...
Matthew Harris is offline   Reply With Quote
Old May 8th, 2008, 10:44 AM   #11
Also, Check out sponser here. I think BH Photo is still one, and they have had indirect specials to get you to Pro 8. Essentially you buy lower version (6 or 7), and then order 8 as an upgrade.
Chris J. Barcellos
Old May 8th, 2008, 10:49 AM   #12
Images: 10
AFAIK, Vegas used to be a top of the line product. As of version 8, Sony seems to have forsaken all camera brands except Sony. My JVC HD110 has dropped frame on capture problems, and I've read similar problems for Canon HD cams. I've called customer support, only to be told after a protracted delay in answering, that it isn't their problem! Since so many people seem to have the same problem, it's a little bit of denial syndrome for Sony to ignore it.
Not sure what Sony is thinking, but, I'm pretty soured on vegas, right now.
Old May 8th, 2008, 12:55 PM   #13
Sponsor: VASST
It might... and it might not... it all depends on what you want to use it for. Without knowing your needs, no one can recommend which version is right for you. Here’s the way I see it:
Vegas Movie Studio: Home user/small business working in Standard Definition
Video: Standard Definition (SD)
Audio: Stereo 16-bit, WAV
Tracks: 8 tracks (4 video, 4 audio)
Transitions & FX: Lots
Differentiating Tools: Chroma Key
Vegas Movie Studio Platinum: Home user/small business working in High Definition
Video: High Definition (HD, HDV)
Audio: 5.1 Surround Sound 16-bit, AC3
Differentiating Tools: Chroma Key, Primary Color Correction
Vegas Pro: Professionals working in either SD/HD that require more tracks and capabilities that the Studio versions don’t have.
Video: High Definition (HD, HDV, AVCHD, HD-SDI)
Audio: 5.1 Surround Sound 24-bit, AC3
Tracks: Unlimited video and audio
Transitions & FX: More than lots. ;-)
Differentiating Tools: Chroma Key Primary & Secondary Color Correction, Video Scopes, 2D/3D Parent/Child Compositing, Multi-Camera, Scripting, Media Manager, more...
As you can see, the tools and capabilities increase with each version with the largest jump going from Platinum to Pro. If you don’t need these tools and capabilities then there is no sense paying for them.
If you are working in standard definition and are just getting started, Vegas Movie Studio will keep you busy for quite while. It has a very powerful set of tools that are probably the best available for the price.
If you are working in high definition and are just getting started, Vegas Movie Studio Platinum will add high def and color correction to the standard Movie Studio tools.
If you are a professional, and need unlimited tracks, compositing, 24-bit audio, video scopes, etc. then you should expect to make your $699 back within your first few customers and it’s a business expense anyway so why worry about the price? ;-) Seriously, don't pay $699. You can get it a lot cheaper. The point is, that it has support for features that you might not need and you can always upgrade later when you do.
If the comparison chart that Edward pointed you too did not answer your questions, then I recommend that the Movie Studio version is probably fine for your needs unless you’re shooting HD in which case getting the Platinum version would be best. Spend the $99 or $149 and don’t look back. You will be amazed at what Vegas Movie Studio can do.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old May 8th, 2008, 01:04 PM   #14
Thank you all.
Great advices.
Old May 8th, 2008, 01:57 PM   #15
I'm no lover of Sony, but Vegas MSP8 has been doing just fine capturing footage from my Canon HV20. My biggest gripe is not being able to batch capture or capture in blocks using timecode with HDV content. And their use of non-standard terms (like event instead of clip).
Rick Diaz is offline   Reply
