Timeline to DVD at DVinfo.net
Old April 25th, 2008, 12:21 AM   #1
Timeline to DVD
Why is there an option to burn a VCD from the timeline, but not a DVD?
I'm needing to burn quicktime clips at 24p to a 24p dvd. The only way I can see to do this is in two stages: Vegas MPEG-2 23.976 (+3-2 pulldown) then render again in DVD-Architect.
There should be a way to do this on-the-fly without the multi-stage renders, but I can't figure it out.
Hmmm... I have CS3 also... maybe I can figure out a way to set this up in Premiere.
rob
Rob Wood is offline   Reply With Quote
Old April 25th, 2008, 04:02 AM   #2
DVDA won't render, only "prepare" (i.e. create the necessary files) a properly rendered file.
If you don't give DVDA the proper file, then it will re-render.
Old April 25th, 2008, 11:55 PM   #3
i believe the question and the context in which it was asked is clear enough... thx anyway.
rob
Old April 26th, 2008, 06:32 AM   #4
Sponsor: JET DV
Rob, as Mike said, there won't be "multi-stage renders". You simply render ONCE. As long as it's a DVD compliant file, DVD Architect will then simply use that file and will NOT render again.
From the timeline, Vegas can do either VCD or Blu-ray without menus. DVD does require using DVD Architect which can create a DVD with or without menus. So after rendering in Vegas, open DVD Architect, do a File - New - Single Movie, pick that one file, and then prepare and burn and you're done. A DVD without a menu which only took a few seconds on your part to create.
Edward Troxel is offline   Reply
