Converting Vegas/Architect DVD files to NTSC at DVinfo.net
Old April 18th, 2008, 09:38 PM   #1
I asked some time ago about saving a file from PAL to NTSC and found with advice and my own reading that it was a piece of cake - simply render out to whatever format you want.
However it appears to be one thing to render to another format in Vegas, and another to produce a DVD with all its menu etc, in NTSC, when the DVD menus etc have all been produced for PAL. Is this so?
I don't want to have to redo all my menus if I don't have to. But if I'm bringing a new file (NTSC) into architect, doesn't that mean that everything has to be redone?
Renton Maclachlan is offline   Reply With Quote
Old April 18th, 2008, 09:53 PM   #2
Could be wrong about this, but I think all you need to do is change your DVDA project properties to NTSC and then preview to see how menus and buttons are looking.
Old April 18th, 2008, 11:02 PM   #3
Now it would be good if that is the case. Hadn't thought of that. Thanks so much. I'll check it out.
Old April 18th, 2008, 11:29 PM   #4
One more question. DVDA has two NTSC widescreen options, 720 by 480, and 704 x 480. Which the common one/best one to use?
Old April 19th, 2008, 07:23 AM   #5
Sponsor: JET DV
720x480 is the common NTSC size.
Old April 19th, 2008, 01:23 PM   #6
Thanks Edward
