Vegas 8.0b and Kaspersky? at DVinfo.net
Old April 18th, 2008, 03:08 AM   #1
In advance of opening a trouble ticket with Sony, I was wondering if anyone else has experienced this problem.
Every time I open Vegas 8.0b I get a 'serious error - terminating' message (well, words to that effect). If I try to load Vegas again it fires up just fine.
Clicking on the 'details' button gives me this load of unintelligible info:
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at System.Windows.Forms.UnsafeNativeMethods.SetFocus(HandleRef hWnd)
at System.Windows.Forms.Application.ThreadWindows.Enable(Boolean state)
at System.Windows.Forms.Application.ThreadContext.EnableWindowsForModalLoop(Boolean onlyWinForms, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.EndModalMessageLoop(ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at Sony.MediaSoftware.MediaMgr.DataAccess.SqlServerUtil.AttachSqlServerDatabaseUsingWorker(MediaLibrary lib)
at Sony.MediaSoftware.MediaMgr.SqlMediaLibraryMgr.Open(MediaLibrary lib)
at Sony.MediaSoftware.MediaMgr.SqlMediaLibraryMgr.OpenLastActiveLibrary()
at Sony.MediaSoftware.MediaMgr.MediaMgrController.MediaLibraryMgrFactoryWorker_Complete(Object sender, WorkerCompleteEventArgs e)
This has only happened in the last few weeks and the only change that I can think of is that I recently installed Kaspersky Internet Security 7 (which I have set to stop as soon as Vegas boots and restart when Vegas ends).
I'm fairly sure that this is where the problem likes but I was wondering if any other Vegas users have already been down this road and found a solution.
Thanks in advance of any suggestions.
Ian . . .
Ian Stark is offline   Reply With Quote
Old April 18th, 2008, 05:38 AM   #2
hi, Ian I am running 8b with Kaspersky no probs and same as you I disable it when using vegas. Have you tried a clean install of vegas..might help
John Estcourt is offline   Reply With Quote
Old April 18th, 2008, 06:00 AM   #3
Thanks John - clean install is indeed my next port of call.
I'm still fairly sure that it's a Kapersky related issue. I'll report back.
Cheers,
Ian . . .
Old April 18th, 2008, 10:03 AM   #4
Uninstalled and reinstalled Vegas. Problem appears to be resolved.
Shame that there isn't any way of saving a preferences file before uninstalling. Very annoying having to try and remember all the little settings that make it my personal Vegas.
(And if there IS a way but I am too dumb to have found it please do NOT tell me now!).
Thanks again for the suggestion, John.
Old April 19th, 2008, 09:27 AM   #5
Ian, do you mean saving your custom render templates?
If so , do this. Please note that I waited a day to tell you :-)
All of the custom rendering templates are in:
C:\Documents and Settings\<username>\Application Data\Sony\File Templates
Where <username> is your windows account name. Just copy them over to your new PC and they should be recognized.
Old April 19th, 2008, 09:43 AM   #6
Mike, you're a good, decent man!
Actually, I was thinking more of preferences, for example the secondary display settings, timeline position etc. That all seems to be lost on a re-install.
Again, if anyone knows different, a delay of 24 hours before telling me would be appreciated ;-)
