Capture issues at DVinfo.net
Old March 31st, 2008, 01:22 PM   #1
Capture issues
I was running 8.0 with no problems on my #2 computer (amd 64 running 32 xp)and could capture until a week or so back. We now get a window that says,
"Hauppage wintv pvr pci II could not be opened".
I restored my computer back to prior, no help
I reinstalled 8.0
It worked for awhile.
Now I get devicer control but when I hit record the widow goes black and nothing is recorded.
computer #1 a P4 has the exact same problem and shows athe prior window mentioned or:
"Cirrus logic usb-dvr2 source could not be opened or is being used by another application."
I went to Vegas for several reasons, stability being one of them.
I know all software has it issues but I am getting a little discouraged after almost three hours this morning accomplishing nothing.
ANY HELP WITH THIS WOULD BE GREATLY APPRECIATED!!!
DATS ALL FOLKS
Dale W. Guthormsen
Old April 2nd, 2008, 01:26 PM   #2
Has no one ever had this problem???
DATS ALL FOLKS
Dale W. Guthormsen
Old April 3rd, 2008, 10:29 PM   #3
All I can find on the problem so far is that some that have had Pinnacle or Dazzle products installed on their computer have had capture problems with Vegas. It is likely a conflict between Vegas and some other program or driver. If you haven't done so already, try a Google search on your error codes and there is some information to be found.
Willard
http://pawildlifephotographer.blogspot.com/
Willard Hill is offline   Reply With Quote
Old April 22nd, 2008, 03:10 PM   #4
Thank you for the suggestion.
It is definitely a driver issue!!!
I have used scenealyzer for some time and it always works perfect so I am continuing to use it instead of the vegas capture.
I believe i need to actually clean the system off and then put the software back on it. Not willing to do that at this time, to busy with work!!
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
