Which files to backup for Custom 'Render As' and Camera Aspect Ratio at DVinfo.net
Old March 14th, 2008, 09:02 PM   #1
Would someone here know which files or registry entries store custom render templates and pan/crop camera settings? I've poked around the Sony directories in Program Files and Documents & Settings but haven't been successful. I did a search on the registry but I must have missed it too. I'm upgrading machines and I had a number of custom 'render as' templates and cinema style aspect ratios. I'm doing them by hand right now, but should I lose the harddrive I'd like to backup the files relevant to this.
On vista I found a Vegas profiles.ini which seems related but didn't seem to have all the details (like the name and such -- just sizes and framerates).
Thanks much!
DIY, 35mm, HV20:
http://www.primitivebuteffective.net
Mike Dulay is offline   Reply With Quote
Old March 15th, 2008, 05:09 AM   #2
I have no idea about aspect ratios but here's the scoop on your render templates.
Thanks to John Rofrano for this.
All of the custom rendering templates are in:
C:\Documents and Settings\<username>\Application Data\Sony\File Templates
Where <username> is your windows account name. Just copy them over to your new PC and they should be recognized.
Old March 15th, 2008, 05:29 AM   #3
The path changed under Vista
Hi Mike, thanks for the reply here and at Vegas Forums.
It appears that the path changed in Vista Home Premium but its very similar:
\Users\<username>\AppData\Roaming\Sony\File Templates
inside the the directories that point to aviplug, mcplug, wm
Additionally there are two ini files that reference the information in Roaming under:
\ProgramData\Sony\Vegas Pro\8.0
DIY, 35mm, HV20:
