#31 |
Color space wrangling (As Glenn puts it. ;) )
The program should know what to do by the source and destination format. |
#32 |
Thanks for the comment, Steven. Couldn't completely agree with you (and Glenn) on that point, regretfully. But this is not the right place to discuss that anyway, I assume :)
OK, let me put it this way: support for YUV in Vegas is a must for me :) P.S. Mike, thanks A LOT for the link to the article covering Trimmer options. One workaround to deal with the absence of Match Frame function could be to use not just In/Out points but regions for inserts. They can be saved so next time the source is opened I can see which portions of it are already in the project. Although it's not a 100% substitute for Match Frame (since it doesn't refer to actual presence of frames in the project), it can still be used provided one will not forget to delete marked but not used regions when switching to another source in the Trimmer. I didn't know that, thanks again :) |
#33 | |
And, if you change from Events to Selected Events, you can double-click a specific event for this information. Isn't this what you want? |
#34 | |
For those of you not sure what we're talking about, I started a new thread with the link to the article. |
#35 |
Not exactly. As far as I understand, to make use of this, I'd have to see details of all the events (cut out from a specified source) I have on timeline one by one and see if the source portion I'm currently looking at has a matching timecode. This will work fine for short source footages as there won't be many events originating from it on the timeline and they can easily be checked. With longer sources, however, with quite a number of events belonging to them -- this can be too time-consuming and impracticable. Regions in the trimmer will deal with this better, in a more convenient way, I think (I only have to make sure I do save used ones and delete those not yet used; or name them so as to easily distinguish ones from the others -- an extra stop or two in the workflow, but should work for me). Have to give it a try and see.
Thanks a lot for the suggestions. P.S. Nice thing to know our origins start at the same place :) You speak Ukrainian? I apologise for the off-top, but can't find an option to write a PM on this forum. |
#36 |
If you click on the "Active Take Name" column, it does a sort so that all clips show up in (time coded) order, according to tape name/number.
I'm not sure if this is helpful in a long-form project but it sure is on short ones. p.s. If you click on a person's name, you'll see an option to send them an email (if they chose that as an option, that is). p.p.s. sorry but no, I don't speak the language. Dad & Mom tried to teach me when I was growing up but, as a young kid, I had other things on my mind. |
#37 |
How about the ability to keep 2 events linked (video and audio) but being able to trim one and not the other. Premiere has this, you hold CTRL and click and drag the "event" in the timeline and it adjusts without affecting the other "event" it is linked to.
This would make J and L cuts much quicker than having to unlink them. |
#38 | |
Sponsor: JET DV
Ignore Event Grouping can be toggled via CTRL-SHIFT-U and there's a button for it on the toolbar.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#39 |
Good point, but I do enjoy just holding ctrl and doing it instead of toggling stuff on and off. I guess that's just my problem with it. I could always adjust the keyboard shortcuts as well.
#40 |
Couple of things I thought of today...
1. When rendering, please institute an "are you sure" dialog for the cancel render. Nothing worse than being moments away from finishing an all night render only to fat finger the keyboard or mouse and lose it all! 2. On render, please put the PATH to where it's rendering along with the name of the file. I know this seems like a small thing, but when I've got a couple renders going, some to local drives and some over the network, it would be GREAT to know where they are headed. |
#41 |
Regarding rendering, it would be nice if you could open a "rendering details" dialog box or extension to the existing box. I've often started a render and then thought, "did I remember to check X, Y and Z?" I then stop the render, find that I had, in fact, made the correct selection, and I start the job all over.
Even worse is that case where you *think* it's correct, and after the job is complete, you find that X, Y or Z weren't checked. Being able to scroll about the timeline to double-check mute settings and such would be good too. Disable changes, but display the rendering state. Call it the Rendering Security Blanket feature.
Jon Fairhurst |
#42 |
How about fixing the cfhd.dll issue for Cineform avi codecs? Jeez it's been two updates since 8.0 and every update I have to rename the cfhd.dll file in Pro 8's folder and use the older 2.5v of the Cineform codec.
Craptacular.
For Stock Footage http://www.revostock.com/ViewProfile.html?&ID=4811 My Website http://www.soundprostudios.com |
#43 |
this'll seem minor but:
1) a collection of ripple-dissolve settings in the Transitions menu (dissolve to dream / past experience). 2) fixing the import image sequence glitch: when applying a fade to a TGA or PNG sequence, this glitch can cause the content to "tear", appearing similar to faulty delta-offset info. 3) 16bit mode, along with 8bit and floating point; i find it preferable in AE and PS (better filtering than 8bit without the colorspace issues of float). 4) allowing videoscopes to display RGB values instead of IRE or % : i get a fair amount of work that is output to RGB. 5) the most commonly used scripts for Vegas organized by category and packaged with the program. (yeh i'm lazy) |
#44 |
I have to second the transitions. OK, we have got a great NLE, but a few additional transitions and effects would really be nice.
I am also anxious for the 64 bit version that was announced for end of 2007. I have Vista 64 bit tested and it does rock. I admit Vegas does perform pretty well as is, but the nerd in me wants to see what happens with the upcoming version. |
#45 |
i forgot...
FOLDERS, like they have in Acid, so i can group tracks and open/close them quickly. AUDIO ANALYZER... they provide scopes for video, but no RMS/Peak/Phase for audio?!? Vegas started off as an audio app; it seems an obvious tool. (having to use a plug-in for it means u can't monitor what's happening while u adjust EQ or compression... see below) MULTIPLE FX WINDOWS... it drives me nuts using filters (audio or video) and not being able to see/use more than one at a time. |
