Event Pan/Crop at DVinfo.net
Old January 26th, 2008, 11:56 PM   #1
Event Pan/Crop
Is there a way to set the Event Pan/Crop tool to not be zoomed in so far when you access it? This is a nag more than anything, but when you're working on multiple clips, and have to find the zoom button and zoom out so you don't lose your nodes, it gets old.
I couldn't find any setting that deals with this.
Jeremiah Rickert is offline   Reply With Quote
Old January 27th, 2008, 08:09 AM   #2
Images: 1
I am not sure if you can change the standard setting but you can use the wheel on your mouse to change the zoom settting without having to select the zoom button.
Curt Talbot is offline   Reply With Quote
Old January 27th, 2008, 10:09 AM   #3
Set the value of the workspace where you'd like it to be, and close the P/C tool. when you re-open...it'll be at the same setting.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline   Reply
