Color Correct in Multicam Projects at DVinfo.net
Old January 10th, 2008, 10:20 AM   #1
When I have two video tracks I want to use in a multicam project, the most logical firist step would be to color correct so the picture from each camera matches nicely. When I place an effect (color correction) on a video track and then let multicam combine them into one track, I get a message stating "some effects will be disabled using multicam" - color correction is disabled. So, that leaves me having to color correct (or paste an effect into) dozens of little clips.
Am I missing something? Is there a better workflow to color correct a multicam project?
Geoffrey Chandler is offline   Reply With Quote
Old January 10th, 2008, 11:20 AM   #2
actually the BEST way to edit, IMO, is to CUT,COLOR/EXPOSURE and finally AUDIO.
Why? Well first you might make changes to the cut. Once you've made the cut then it's a lot easier to do CC and Exposure correct if needed and with multicam shoots, if you're using the audio from the cameras (not a seperate audio recorder) then you migh use audio from some or all the cameras not just the "A" camera.
Over the years I have found this system works the best. Do my CUT first then I can concentrate on color and exposure and finally audio work. It just seems to work out better at least for me.
Then you can do CC to the clips (events) or in the media pool whichever works best. Don't forget that once you've CCd one clip you can make that a preset in the CC FX and highlight all the clips that you want to use that FX on and simply bring it to them all at once.
Don
Last edited by Don Bloom; January 10th, 2008 at 11:22 AM. Reason: forgot something
Old January 10th, 2008, 11:28 AM   #3
Geoffrey, I haven't tried this yet but can't you do your CC'ing after the multicam edit is done?
That is, figure out your CC settings, save them as presets (use a plug-in chain if there's more than one FX), do your editing and then reapply them to the clips in the media pool, not on the timeline.
This way, the entire clip is corrected at once.
Old January 10th, 2008, 11:46 AM   #4
Yes I can Color Correct after the edit, but I didn't think it was very efficient to have to find all the little pieces of video (after being cut up by multicam) and apply an effect to each and every little clip.
Now, you mention using the Media Pool. I guess I don't know how that works. Can I apply an effect to a whole file even though it's cut up in the timeline?
Old January 10th, 2008, 12:03 PM   #5
Sponsor: JET DV
If you apply an effect in the Project Media, it will be applied to that clip wherever it is on the timeline - no matter how many pieces it is or over how many tracks it is located.
Old January 10th, 2008, 12:46 PM   #6
There's the answer. Thank you very much.
I have to say, I love this program. I've been a hold out with Premiere 6.5 for many years thinking I would be the most productive with a program I knew well, instead of continually trying the "latest thing," having to learn new software. I’m glad I gave Vegas 8 a try because I can see already after just two jobs, it is going to really speed up editing.
Old March 26th, 2008, 12:13 AM   #7
I've been playing with this new [to me] concept for a while and can't figure out how to view what's going on as I try to apply CC to a clip in the Project Media. Can someone clue me in to just how this is done, please? :)
Lorinda
Old March 26th, 2008, 07:27 AM   #8
Sponsor: JET DV
Lorinda,
Put the clip on the timeline. Make sure the cursor is on that clip so you can see it in the preview screen. Now go to the Project Media, select that clip, and click on the "FX" button to add an FX. As you adjust the FX, the changes will be seen on the preview screen. The key is making sure the cursor is over that clip so you can see it in the preview screen.
Old March 26th, 2008, 10:02 AM   #9
Ah…thanks, Edward! Unfortunately, when dealing with a LOT of clips (as I am this time), it’s probably just as time efficient cutting without using the multicam feature and applying effects on a track level. It’s a good case for leaving the camera running for that nice, long clip!
Lorinda
Lorinda Norton is offline   Reply
