Slower rendering in Vegas Pro 8 (?) at DVinfo.net
Old January 6th, 2008, 05:10 PM   #1
I recently upgraded to Vegas Pro 8, and subsequently the 8A update.
I have noticed a few things that are actually inferior to Vegas 7e that I was using. I mainly shoot and edit HDV.
I had no problems with 7 through 7E.
Vegas Pro 8 takes a LOT LONGER to render. For example, with an HDV edit, I could render to MPEG2 for SD DVDs at a rate of about .7x timeline length. For example a 100-minute show would render in 70 minutes. I also render to WMV-HD, so it would take about 8x timeline length for 720p and 13x timeline length for 1080p.
On my last job, a 90-minute wedding, it took about 4.5 hours to render mpeg2 files for SD dvd. The program crashed trying to render to WMVHD, so I had to render to m2t first, then bring that into Vegas 7 to render to WMVHD.
It always crashes when trying to render to an AVI intermediate.
I have been able to render WMVHD in Vegas Pro 8 with short shows, like 3-7 minutes.
Mark Goldberg is offline   Reply With Quote
Old January 6th, 2008, 08:45 PM   #2
Is your project set to 32 bit ? I know it takes A LOT longer to render 32 bit than it does 8.
Ron Chau is offline   Reply With Quote
Old January 7th, 2008, 03:18 AM   #3
Vegas 8a render results on my 2.4Ghz Quadcore XP 2Gb RAM
FYI - I agree on the "slowness" comment.
I ran a render of 1 video/1 stills/2 audio tracks with 2 video filters and 2 audio filters per track. Clips originally captured using Cineform HD at 1920 x 1080. Total clip time = 40 seconds. Vegas 32 bit processing on.
RESULT 1.
Rendered the clips using cineform HD codec to 1920x1080 (ie near lossless)
Result = CPU usage around 30% peaking occassionaly at 50%, and once going up to 60%. Never any higher.
TOTAL RENDER TIME = 20 minutes
RENDER RESULT 2.
Rendered same 40 sec clips using Mainconcept MPEG2 codec to DVD PAL 720 x 576
Result = CPU usage around 65% peaking at 75%.
Total render time = 3 minutes
RENDER RESULT 3.
Rendered a longer 2m10sec clip in 5 min 40 sec
I'll now run these with Vegas 32bit turned off.
Sherif
Sherif Choudhry is offline   Reply
