Thread Tools
Search this Thread
Audio Volume Envelopes?
I think that's what they're called. I want to add ramps to the volume, without having to split a clip up and adjust each one manually. Does anyone here understand what I'm trying to do?
Any help would be appreciated. SB |
Highlight a track header and press the "v" key. Or, right-click in the header and pull down to "insert/remove envelopes".
Instant envelope. Now, double click on the envelope to create a point which you can drag around... and right click on a point for additional options. Note that it takes two points to define a volume change, and that you can drag the envelope line itself. |
