where is H.264? at DVinfo.net
Old December 19th, 2007, 09:39 AM   #1
where is H.264?
I remember someone posting here (or was it another forum? -- I conducted a search with no results) how to locate QT's H.264 codec in Vegas 8. I also remember checking that information out at the time and indeed it was there. Now, for the life of me I can't remember what to do to make the codec appear in a list. Does anyone have this information?
Paul
Paul Fierlinger is offline   Reply With Quote
Old December 19th, 2007, 07:27 PM   #2
Pretty sure you pick a container, like .mov, then you pick the codec and adjust the settings.
Joe Busch is offline   Reply With Quote
Old December 19th, 2007, 07:34 PM   #3
But what I want to do is export my project for someone who needs it to be an H.264 QT movie. In that case I need to first locate the codec under "Render as" and render it to a HD folder. I have QT Pro 7.2. Shouldn't I be able to find the codec within Vegas?
Paul
Old December 19th, 2007, 09:28 PM   #4
If you go to render as, quicktime, custom, video format you should find H263 not 264, I would like to see H264 too, I have Quicktime H264 in AVS video converter, which works, In QT I always use Sorenson codec
Hugh Mobley is offline   Reply With Quote
Old December 19th, 2007, 09:32 PM   #5
Here's 3 suggestions from the Sony Vegas forum.
#1. File -> Render As... Type: Main Concept AVC/AAC
#2. Use Sony's AVC encoder if you don't like Main Concept's. Select the appropriate resolution and bitrate for your video & the end result will be good. The .mp4 extension is actually preferable as it's more compatible with devices and apps.
#3. Render an uncompressed AVI, open it in Quicktime Pro and compress it there.
Old December 20th, 2007, 12:21 AM   #6
Thank you Mike, that was the one I was looking for! So I had seen it in the Sony group.
Hugh, I have no preferences in this case-- I've been asked to deliver H.264
Paul
Old December 23rd, 2007, 07:25 PM   #7
hi Paul. Have u attempted the 3rd workflow? I'm gonna try it tonight to see how it goes. I learnt from Phil (UK) that those wonderful H264 stuff he shot with the Sony EX1 went thru 2 steps to render. Render to mov (current settings in FCP6) and then a 2nd render via QT Pro to H264. The results are amazing.
Old December 23rd, 2007, 10:04 PM   #8
Hi Sean, yes through QT Pro was what I ended up doing. I have no regular need for H.264 in my line of work (I'm a 2D animator, so no cameras are involved and I work with uncompressed avi's) but it did look very nice and fit the needs of my MacHead colleague who had asked me for it.
Paul
Old December 23rd, 2007, 11:31 PM   #9
thks for the feedback! Will have a go at it and see what happens. I think QT runs better on the web the HD WMV somehow.
Old December 24th, 2007, 03:23 AM   #10
I don't know that much about website building, but I always thought it was the opposite. I think QT can be played by anybody but WMV is more restricted to PCs. I have HD WMV clips on my website, which are pretty big and don't think QT could match them with practicality.
www.mydogtulipfilm.com
What I do like about QT is the way you can scrub them frame by frame, which is important for most animators.
Paul
