Network Rendering (what is wrong) at DVinfo.net
Old December 17th, 2007, 09:24 AM   #1
Is there a guide somewhere to fully understand the network rendering option? I have Vegas 8 on 3 computers and all have the network render application started. I'm able to see the other clients in the drop down menu when the network render box pops up. Whenever I try to distribute the render it says queued on the clients computer whereas on the host it says the clients are "working". Seemingly it looks as tho the client computers are not "working".
If I change the host to any of the other computers then it will start working on the host only. How do I get them to shake hands? There's got to be something simple I'm not doing correctly. I've got my paths set up to share the same drive (f:\render) for the host (hostcomputer://f:/render) for the clients. Thanks in advance.
Roger Akers is offline   Reply With Quote
Old December 17th, 2007, 09:46 AM   #2
Sponsor: JET DV
You might try reading through this thread:
http://www.sonycreativesoftware.com/...ssageID=554664
Old December 17th, 2007, 10:05 AM   #3
Matter of fact I already have. I don't understand any of what that guy is saying and was wondering if anyone on this particular forum has any experience with it that could explain it to simpler. I'll re-read for the time being tho.
Old December 17th, 2007, 10:29 AM   #4
Images: 10
I think the problem is with the way Vegas looks for domain names. I finally got my networked render farm working by doing the following:
1-right click on my computer and select PROPERTIES
2-select COMPUTER NAME tab, then click on CHANGE
3-when the name change window opens, click on MORE
4-enter a name in PRIMARY DNS SUFFIX, then use this in the setup
Old December 17th, 2007, 11:22 AM   #5
Yes I have changed the name.
It does not seem to be in name resolution issues but rather it seems like it's trying to figure out where all the files are located. Before I changed the name like your advice it would say failed on the client computers. Now it says queued on the clients yet never starts "working" like the host.
Old December 18th, 2007, 03:34 PM   #6
stupid question: are the files / folders set as shared? Sorry for the "is it plugged in" idea!
Sam Houchins II is offline   Reply With Quote
Old December 19th, 2007, 11:50 AM   #7
Yes everything is shared and I BELIEVE the paths are correct in the vegas network renderer. I've been trying to figure this out since i started the thread and still no luck. I can see that all my clients are ready and sometimes they say queued, or working and they always fail.
Old December 19th, 2007, 01:50 PM   #8
VASST usually has some good answers when it comes to Vegas - try checking out their website @ http://www.vasst.com
Kit Hannah is offline   Reply
