version 8 question
I'm getting frustrated with Vegas 7's handling of filter keyframes. If I have a clip that has several filters stacked and I have set a starting keyframe for everyfilter. Now I want to replicate this stack on another clip.. I have to manually add each filter and then copy the keyframe over one by one.. Does version 8 allow you to copy all the filters+keyframes from one clip and pasting it to another clip?
Any chance that Sony Vegas will be ported to OS X? MacPro+Sony Vegas. That'd be sweet.... The only reason I'm still using a PC desktop is for Vegas.. |
Is it just one keyframe you have for each filter, ie the values don't change on the timeline? If so you could use a filter package which will save a chain (or stack) of filters along with their settings as a reusable group. Then simply apply that package to other clips, tracks etc as required. This exists in v7 already.
If it's multiple keyframes that animate the filter over time then I guess you're into copy and paste (although the filter packages will save time setting up all the plugins every time.) Hope that's of use. |
I'd have to check this but try copying the original stacked clip and then 'paste event attributes' to all the other clips. I think this should copy all the effects/settings. I'm not 100% on the keyframes if it does that too.
For Stock Footage http://www.revostock.com/ViewProfile.html?&ID=4811 My Website http://www.soundprostudios.com |
#4 | |
Sponsor: VASST
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins Web Site: www.johnrofrano.com |
