Vegas FX Filters - Does order matter? at DVinfo.net
Old November 29th, 2007, 08:11 PM   #1
I am applying 3 FX filters to converted Hi8 tapes.
They are:
Color Correction
Brightness & Contrast
NeatVideo
Is there any general rule as to which filter should be applied first?
thanks...alan
Alan Henderson is offline   Reply With Quote
Old November 29th, 2007, 08:52 PM   #2
Sponsor: JET DV
Yes, the order can matter. The second one will see the frame AFTER the first one is applied and so forth. BTW, you probably really don't want the "brightness and contrast" effect. Try adjusting the gamma and other settings in the color corrector instead.
Old November 29th, 2007, 11:19 PM   #3
Yeah, either that or use the Curves instead.
Triple E Productions - Award Winning Films/Services
www.PaulDV.com
Paul Del Vecchio is offline   Reply
