Vegas support Red digital?
Wondering if I went with a red camera does Vegas support it? are there inherent drawbacks? can I use gearshift to work on proxy files?
Thanks Stephen Eastwood http://www.StephenEastwood.com |
#2 | ||
I believe Vegas should be able to natively edit the quicktime reference files. Rob Lohman (one of the coders for Red) uses Vegas.
http://www.reduser.net/forum/showthread.php?t=2452 Quote:
Max Res is 2048x2048 which I'm OK with given the very reasonable price.
So technically it does not in full res so it would never be smart to use it to edit since you could not render a final output fullsize.
I am curious if they ever will ad it as I see the red as a viable upgrade to many from hdv/xdcam |
#5 |
No Vegas is not the editor to do a full res render from red but then there is very little than can handle that. Not even the most common commercial projector from Christie can handle more the 2048. There is no main stream common commercial use for more than 2048. OK I'm sure there are uses and for those special limited needs you need to pony up the big bucks for an NLE that can handle RED and it will cost a lot more than $135.
Sorry this is just a pet grumble with me people want better resolution than the last Star Wars movie when shown with digital projectors on the BIG screen (1080x2048) for $135 they are asking for a free lunch in my not humble opinion. |
#6 |
Think you are looking at it the wrong way, I have final cut, vegas, adode, and avid liquid, I don't mind spending the money at all I do however mind spending the time to learn and get good at a NLE that cannot handle something I will want and have to learn a whole new program all over again to work it later.
#7 |
Right now what you can do is:
A- Master to HD resolution (1920x1080) or 2K (2048x1080; which you can crop to HD). For video, it's unlikely you'll need to make material at higher resolution than that for a few years. Some theatres can show 4K (though 2K projection from a Christie looks better than Sony's 4K) but to make a compliant master you need specialized tools and a 4K projector. It makes sense to do that type of work at a facility that can handle it. You need a very fast disk array, software that can make a DCI package, 4k monitoring, etc. etc. All that requires some $ and just as importantly the expertise. B- For extract 4K stills from Red, go into Redcine and export your stills. 2- Perhaps a smarter way to work is if the NLE had integration with Redcine so you spend less button pushing in making your stills. Perhaps you could change the timeline to 4K and the quicktime reference files to 4K (though I don't know if the NLE will like that since it might think that the clip is still 2k). |
#8 |
If Vegas can support the proxies created by the Red camera (via RedQuick), then it should be able to work as a 4K editing solution.
Boycott Guinness, bring back the pint!!! |
