Laptop for Vegas
Hi fellow videographers
I'm soon heading to the US to do a 3½ week project, and for the occation i need a laptop to be able to do some on-the-fly editing. The budget is extremely limited, but this is what i have come up with: http://www.newegg.com/Product/Produc...82E16834115372 http://www.newegg.com/Product/Produc...82E16820144183 http://www.newegg.com/Product/Produc...82E16815123013 (Sorry if it is illegal to link to a non-sponsor site, but afaik you cannot buy pcs and stuff from them) Is this completely useless? I will use it together with a WD external USB2 harddisk, for file storage and stuff. It will be used to capture video from a vx2100e and a backup canon mv630i, so nothing big and fancy, just good'ol NTSC interlaced. Thanks for any inputs you might have. Mark
Carpe Noctem |
First item - No. The reviews aren't very complimentary either re the way Vista performs on this model. And it's Vista Home Basic - the lesser of the versions.
Second item - to get maximum performance, you need to put DDR2 RAM in matched pairs. So if you want 1GB, you really should get two 512MB modules. According to the specs, it has 1 x 512MB, so to get 1GB, you just need a 512MB that matches. 1GB is the minimum you should go with. If your budget can cover it, 2GB are much better especially for video editing on Vista. Third item - No problem. I have a PCMCIA FireWire card for one of my laptops and it's fine. Consider this laptop: http://www.newegg.com/Product/Produc...82E16834115383 It's $100 more but has 1GB RAM, Vista Home Premium (not Basic like the other one) and a faster processor. |
Thanks for the fast reply.
Regarding the ram, ill buy 2 gigs of DDR2 to pair up. Doesen't cost too much anyway. Honestly, im not a fan of Vista at all - so, my plan was to format it, and install windows xp pro sp2 instead. I should have mentioned this earlier. The fact that it is a somewhat china-quality PCMCIA card shouldn't do much of a difference, no? I'm pretty hooked on the laptop i chose there - and i dont really have a budget to buy the bigger model you linked to, although its tempting! Links for the new ram is here: Criucial is good, right? http://www.newegg.com/Product/Produc...82E16820146517 Thanks again Mark
Carpe Noctem |
#4 | |||
I'm answering these out of order to do the simple ones first(!)
So, I would see if Acer provide the option to get XP Pro instead (but it will put the price up I suspect) and, if possible, configure the laptop with 2GB from the factory. If Acer can't do that or provide an XP installation disk for that laptop, then, assuming the laptop comes with a Vista installation disk that will put the laptop back exactly to its original state as you got it [many don't], wipe the hard drive and try installing XP from a standard XP CD. If it fails, then you can simple reprep the laptop with Acer's Vista CD. DON'T DO THIS IF YOU DON'T HAVE THE ACER VISTA CD! You'll be left with a blank hard drive. (Almost) finally, if you are able to put XP on there, you will almost certainly need to download drivers from Acer for various bits of hardware. Here's the link for the Acer systems: http://www.acerpanam.com/flex/acerdr...n/drivers.html AFAIK, all of this hinges around whether the hard drive is SATA or not. Acer's own specifications for this particular laptop doesn't state one way or the other. If it isn't SATA, there's a high probability of success installing XP. Sorry to be a scaremongerer... |
#5 |
Thanks for the great reply John!
I have looked a bit into this, and on the page you linked to, there are some drivers available for both Vista and XP - which means that it must be possible to install XP one way or another, the question is just, how? The only place i have been able to find any info about the harddisk type is on a danish homepage, and, too bad, it is a S-ATA (Or good i guess, much better performance.) Now i am sending an email to Acer's technical support, to hear if it is possible to install XP without any major hassle. I am madly in love with this computer (and so is my wallet), so if i can confirm that it is possible to install Windows XP, i will be really happy. I will probably install Norton Ghost on the machine when i get it, so, if i do not succeed in installing windows XP i will be able to get it back to its original state. At the price, it is simply too cheap not to give it a go! Thanks once again for the great reply!
Carpe Noctem |
#6 | |
Crucial
But asside from that, I have never had problems with my Crucial ram and I have purchased it for 3 different computers over the past 7 years. |
#7 | |
Carefull
If you "wipe the drive" do it carefully and only for the bootable partition. |
#8 |
Hi Jason.
I am a former overclocker, and i think i remember hearing good things about the crucial ram - so i have no hard feelings buying a couple of gigs of those. I won't even bother buying a recovery-cd, since i have bought a copy of norton ghost a couple of months ago, which will do the job quite perfectly. No reason to pay $20-30 for a (maybe) useless CD, when i can do it myself and be completely sure that it will work perfectly. It seems that Acer's technical support is a bit slow at responding, but i will keep you all posted as to what i find out. If i can get this to work you can have a complete, portable, vegas editing station for less than $600.... If anybody has any experience installing XP on these machines i'd really like to know! Mark EDIT: Oh no.. i just fell in love with another PC! http://www.newegg.com/Product/Produc...82E16834101086 Several reasons - 1. Bigger harddisk. 2. Faster Processor. 3. BUILT IN IEEE 1394! Only one minus - it is a recertified model. Does this have a big impact on the product i will get, or is it pretty much the same as a new one ? EDIT2: And im 99,98% confident that i will be able to install XP on this one! http://support.gateway.com/support/d...param=1014312R (the top driver is a S-ATA driver, which is compatible with both Vista and XP!!)
Carpe Noctem Last edited by Mark Olsen; September 21st, 2007 at 03:31 AM. |
#9 | |
So, you might as well try a generic install. If it fails, try the slipstreaming option. BTW, I bought a refurbished Gateway desktop last year and I haven't had any issues with it - I just saved a few $100.... |
#10 |
Thanks for all of your help, it is really appreciated. I will buy the gateway when i get to the US. (and install XP on it.. muhahahahah)
Carpe Noctem |
