Thread Tools
Search this Thread
Simple administartive Question about Vegas
Can you use Vegas on both your desktop and laptop? Does the Sony registration scheme allow you to have two active copies?
The short answer is yes.
Here's the long one :-) Answer ID 455 from the Sony Knowledgebase. Question Can I run my Sony Media Software application on more than one PC? Answer Our licensing agreement permits you to install the software on as many machines as you own, as long as you are not running the programs at the same time. For instance, you can install the software on your home machine and on your laptop. You are not allowed to install the software on multiple machines if you are going to be using them simultaneously, such as in a home studio setting. If you are going to run the software concurrently on more than one machine, you would need to purchase a separate license for each computer. Note that when you install the software on a different computer you will need to complete the registration process again. Register the software as you did the first time to unlock the program on each machine. You can register online directly within the software, via the phone, or on our website through our online form. |
