Vegas 8 with V 7 settings?
How can I apply my V7 settings to V8. Also this: V8 now plays back at about 1 or 2 frames a second instead of the 24 fps I have it set for. What do I need to do to get everything running at least as well as it did in v7? Will restoring to my V7 settings do this? Dismayed...
EDIT: I am running under Windows XP
Paul |
Concerning window settings: these settings are stored within the windows layout. You could try to copy the file associated with each window layout setting to the new 8.0 folder.
See: C:\Documents and Settings\Username\Application Data\Sony\Vegas\7.0 and: C:\Documents and Settings\Username\Application Data\Sony\Vegas Pro\8.0 Concerning other preferences: I think you have to go through the Options/Preferences again. I did it this morning (just purchased V8) and it took me 15 minutes to get back on track. Didn't notice any dramatic slow down of playback (until I switched on the 32-bit floating point function...). Kind regards, Erwin |
Thanks for the quick reply. I restored my old settings from memory as well and I fixed the playback problem by changing the pixel format back to 8 bit in the project properties. Right now I seem to be back to where I was happy in V7.
Paul |
copy
C:\Documents and Settings\Username\Application Data\Sony\Vegas\7.0 to C:\Documents and Settings\Username\Application Data\Sony\Vegas Pro\8.0 This indeed does work, plus I have my Suttle Pro 2 settings back as well.
Paul |
#5 |
Shuttle Pro Settings
Does V8 require an updated driver for the Shuttle Pro? Or do you only need to point it to V8? Thanks, Brian |
#6 |
I had custom made settings for my V7 so I just pointed those to Vegas 8 -- very simple.
Paul |
