Audio clean-up: rain noise
I am editing together a wedding video using footage shot by someone else.
The footage was initially in .MOD format. When I finally realised that this was mpeg2 and I rerendered to DV/AVI, I couldn't believe the performance improvement in Vegas! But now, I am dealling with some serious rain-noise problems in the audio. I think that camera was being held under and umbrella, so the rain noise is comparabel to the crackling of a fire. My question: what would be the best way to try and reduce this noise. I am not an audiophile, so I have not done any serious analysis work on this problem. I initially tried using the default track effects (noise gate, EQ and compressor), and had a little success there, but I imagine the real solution may lie in identifying "rain drop/pock" frequencies and attempted to minimise them. What do people suggest? All help greatly appreciated. Ciao, marks --- Vegas 7.0e/SF 8.0/AMD64 3500+ |
Do you need the audio from the camera? Or can you just put music ontop... :)
Rain noise consists of a wide range of frequencies and varying levels. It will be virtually impossible to fix this.
For a good deal of it I can fudge out the rain, but there are a couple of segments where poems are read and vows are spoken - really want to keep those.
I realise that it can't be fully removed, but if I can reduce its impact. I'll fiddle about and see what I can do. Many thanks, marks |
#5 |
#6 |
Download the demo from GoldWave.com and try out its noise reduction. As mentioned, rain is tough, but it's worth a shot...
Jon Fairhurst |
#7 |
Thanks Jon,
I'll give the goldwave product a go. Appreciate the suggestion. marks |
#8 |
Try Audacity
Hugh Mobley www.petplanetvideos.com http://exposureroom.com/members/hmobley.aspx/ |
#9 |
I haven't used Audacity, but GoldWave is very good. It has a very liberal demo policy, and only costs $50. I recently purchased Sound Forge 9, and to be honest, I think GoldWave's noise reduction compares favorably with SF9's NR. I keep using SF9 though, just because it cost more. Silly me! (I should really do a head to head test next time I have a tough NR job.)
Jon Fairhurst |
#10 |
Audacity is a free program, you will have to play with the noise removal settings, but it does do it.
