Media going offline then crashes at DVinfo.net
Old August 24th, 2007, 12:01 AM   #1
Im trying to edit my home videos from Hawaii and the media keeps going offline . If I get to a point if I try to render and I pick the place to render to it says a bunch of clips offline. If I do anything it crashes. My preview is also freezing or running low FPS.
I went on vacation and cant get it to work right now.
I un-installed E and went back to D but it does the same thing.
Im have 3gb of ram but it only is using about 1.5gb .
This is the the last error I got befor it crashed.
Sony Vegas 7.0
Version 7.0d (Build 192)
Exception 0xC0000005 (access violation) READ:0x0 IP:0x0
In Module 'vegas70.exe' at Address 0x0 + 0x0
Thread: GUI ID=0xF04 Stack=0x126000-0x130000
Registers:
EAX=04acb4f0 CS=001b EIP=00000000 EFLGS=00210206
EBX=2e61e508 SS=0023 ESP=00126f34 EBP=00000000
ECX=33c8ffff DS=0023 ESI=2e61e508 FS=003b
EDX=00000000 ES=0023 EDI=06fef1a8 GS=0000
Bytes at CS:EIP:
00000000: .. .. .. .. .. .. .. .. ........
00000008: .. .. .. .. .. .. .. .. ........
Stack Dump:
00126F34: 004548CD 00400000 + 548CD (vegas70.exe)
00126F38: 04ACB4F0 04800000 + 2CB4F0
00126F3C: 0F73DBB0 0F340000 + 3FDBB0
00126F40: 006E1542 00400000 + 2E1542 (vegas70.exe)
00126F44: 2E61E508 2D6B0000 + F6E508
00126F48: 2E61E508 2D6B0000 + F6E508
00126F4C: 0F73DBB0 0F340000 + 3FDBB0
00126F50: 00000000
00126F54: 00000000
00126F58: 02477188 02350000 + 127188
00126F5C: 000005A0
00126F60: 00000438
00126F64: 00610068 00400000 + 210068 (vegas70.exe)
00126F68: 00610077 00400000 + 210077 (vegas70.exe)
00126F6C: 00690069 00400000 + 290069 (vegas70.exe)
00126F70: 0030002D 002C0000 + 4002D
> 00127170: 0044731D 00400000 + 4731D (vegas70.exe)
0012FFF0: 00000000
0012FFF4: 00000000
0012FFF8: 009302DB 00400000 + 5302DB (vegas70.exe)
0012FFFC: 00000000
My videos
http://www.youtube.com/user/lucasberg
Joey Atilano is offline   Reply With Quote
Old August 26th, 2007, 12:40 PM   #2
Not clean uninstall
Hi,
had similar problem - mediamanager was looking for a offline media library and refused to start or re-install.
The uninstall does *not* delete the pref files when uninstalling, they are still in the
Document and Settings / [user] /Application Data / Sony / Media Manager
folder. You have to manually remove that folder after uninstalling , and possibly clean your registry with (the very useful) tune-up utilities from
http://www.tune-up.com/
/magnus
Magnus Helander, Crossmediageek on G+
Magnus Helander is offline   Reply With Quote
Old August 26th, 2007, 05:26 PM   #3
Thanks Magness
My videos
Old September 3rd, 2007, 10:10 AM   #4
Man , I was never able to to find those folders you said to delete.
Now I have my a new trip I want to edit and the media keeps going offline and I cant edit or render.
I didn't install media manager is that it maybe?
Any help would be great ,this is so frustrating!
My videos
Old September 6th, 2007, 07:41 AM   #5
I had the same problem, and boy it's annoying when you know Vegas normally works so well!
In the end I discovered that it was because some of the rushes I imported into Project Media were suspect. On one of my tapes I'd forgotten to hit the Return button to respool the tape when turning the camera on after a break. I ended up with 2 or 3 seconds of what was last on the tape which was SD and not HD which the project was!
I had to re digitise the footage and not let NEO see the format blurp change by pausing and spooling forward past it! Since eliminating the format change from my rushes all is ok! So maybe there's something on your rushes which is upsetting Vegas.?
Try looking through your rushes on a monitor before importing into Vegas, keep your eyes on the timecode for jumps or anything else which may cause an error like this.
Delete everything you've put in so far and redigitise from scratch. It might be worth a try.? It took me ages to find out what it was!
Good luck!
Stuart Campbell is offline   Reply With Quote
Old September 7th, 2007, 03:04 PM   #6
I just finished editing my video but I had to endure 17 crashes. I will try that next time when it does it again.
My videos
