IMPORT HELP - Dig. Cam AVI to Vegas7 at DVinfo.net
Old August 12th, 2007, 01:19 PM   #1
I have AVI files on my hard drive from a Finepix s5200 digital camera - they play fine in Windows Media - BUT only Audio imports into Vegas7
I have a two day deadline for this project PLEASE HELP!!!!
I found a work around - but it is lengthy - I imported the clips into Windows Movie Maker (which recognized both video and audio) and rendered to a wmv. file - which then imports fine into Vegas 7.
I would still DEARLY love to know how to import them direct into Vegas though - as the thought of pre rendering EACH file through Movie Maker is enough to make me ....sick.
-N.M.
Nolan Mackie is offline   Reply With Quote
Old August 14th, 2007, 07:21 PM   #2
Sponsor: JET DV
Does it use an MJPEG codec? If yes, do a search here for MJPEG to find a codec you can download which will allow the video to work. If not, figure out what codec is needed, download one, and install it.
Old August 17th, 2007, 05:52 AM   #3
MJPEG Codec
I have no idea what codec it uses and I do not know how to find out. - All of my Media player play it ok - so I assumed the codecs were not an issue. Do you have to load Codecs specifically intro Vegas?
Old August 17th, 2007, 06:11 AM   #4
Go here and download the MJPEG V3 codec trial version. That'll fix your problem.
Guy Bruner is offline   Reply With Quote
Old August 17th, 2007, 07:48 AM   #5
Sponsor: JET DV
There are different types of codecs. Vegas uses the "Video for Windows" codecs. You obviously have a codec that works in WMP but it's not a "VfW" codec.
Edward Troxel is offline   Reply
