How do I add fonts in Vegas 7? at DVinfo.net
Old August 11th, 2007, 03:38 PM   #1
I'm struggling trying to figure this out. I thought I would be able to find a font folder within the Vegas program, but I can't find the folder. Can someone tell me where it is located so I can add some fonts I downloaded from the net? Thanks.
Michael Vaden is offline   Reply With Quote
Old August 11th, 2007, 04:06 PM   #2
Got to your window's control panel and click fonts, then add fonts. once you do this, you will be able to use them in any program on your system, including Vegas.
Bennis Hahn is offline   Reply With Quote
Old August 11th, 2007, 04:06 PM   #3
C:\WINDOWS\Fonts
Emre Safak is offline   Reply With Quote
Old August 11th, 2007, 07:09 PM   #4
Vegas will recognize the fonts added to the Windows folder, and they'll show up in your Text generator. There isn't a mechanism that allows you to add fonts only to Vegas.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old August 11th, 2007, 07:20 PM   #5
C:\WINDOWS\Fonts
As Emre indicated you can drop them in this folder.
Don't get too carried away, it impacts system performance if you add too many (I can't remember offhand how many, I think it's 400 or more.) Conversely, you need to retain the following fonts:
- Arial
- Courier
- Courier New
- Modern
- MS Sans Serif [two may appear as MS Reference]
- MS Serif
- Symbol
- Tahoma
- Times Roman
- Wingdings
When adding/removing, try to add/remove the whole family, e.g. bookman, reg, bold, italic, etc.
PS: The Font Thing is a good little tool to help you manage your fonts.
James Harring is offline   Reply
