Would this mp3 recorder at DVinfo.net
Old April 22nd, 2007, 04:34 PM   #1
Hi guys
Could anyone tell me if this mp3 recorder would be suitable like the iriver as a back for capturing audio?
Have a look at the link
http://www.dooyoo.co.uk/portable-mp3...12-mb/details/
Wayne Greensill is offline   Reply With Quote
Old April 22nd, 2007, 05:57 PM   #2
Based upon the specs, it only allows use of the built-in mic, which is very likely useless.
You need external mic access to make this kind of device usefull.
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old April 22nd, 2007, 08:35 PM   #3
It does have a line in (look under the Connections section of the specs). So the next question would be if it has a lock function. Once you start it recording you want to lock the controls so that it can't be accidentally turned off. If it has that then it looks like a winner. Pretty much a trendy iRiver.
Ben
Ben Lynn is offline   Reply With Quote
Old April 23rd, 2007, 10:27 AM   #4
Not only that but pre-amp circutry to boost and monitor the input signal.
And as far as the "lock" everyone touts as necessary - nothing a piece of scotch tape can't cure.
Rick Steele is offline   Reply
