#16 |
As I understand this, the claim that any DV camera has a resolution like that is pure marketing hyperbole, since the maximum possible recorded resolution of the DV format is 540 lines. Sure, you can have a lens and sensor capable of resolving more than that, but any such potential is lost once you've recorded that to tape. That's the beauty of HD: you can actually capture and deliver real resolution of 700-800 lines, something which is technically impossible with DV.
#17 |
tell that to all the guys still shooting with high end sony ENG's from the 350, to the 570 to the 450.. its all DVCam though......
#18 |
#19 | |
P.S. Part of the problem here is inconsistency in how resolution is being measured. The most neutral measurement is lines of resolution per picture height, which can't be more than 540 for DV or DVCAM in the NTSC format. Anything beyond that probably refers to total horizontal resolution, which logic suggests can't be more than 720 for DV or DVCAM -- but some manufacturers report values up to 800. In the Texas HD shootout, the resolution values stated appear to be lines per picture height, so the 700-800 lines mentioned exceeds the maximum value of 540 for DVCAM by a substantial amount. Last edited by Kevin Shaw; April 8th, 2007 at 06:50 PM. |
#20 |
Unless I'm missing something, DVCAM is just DV run at a different tape rate,
((Nope yoru not wrong, your on the money bro)) and still has 720x480 pixels with maximum TV lines per height of 720/4 *3 = 540 lines. Anyone who believes DV or DVCAM can deliver more TVL resolution than that is therefore incorrect. ((yah... true.. and theres no debate about that..and theres no debate about teh tape based elements here.. reason i said DVCam is because thats the format these guys shoot in, and they STILL believe its hitting 70 lines.. if they were pumpin out straight to a mixer or whatever and recrding as DV50 or uncompressed, then yeah, i'll give them their 700 lines, but theyre not, theyre only using tape. and no, its virtualy no different from DV save for tape rate (which allows for tighter audio sync... however most newer cameras dotn have the issue of slipped audio) Another thing to take note is the overscanning areas..some manufacturers, use this in their numbers to jack it up a lil as well.. |
#21 | |
What happens if I push the 'Red' button? |
#22 |
i dont think its the "demo factor" alone.. i also believe that many are showing work shot and edited by other people (ie same company different shooters) and selling THAT product when in fact the sales consultant KNOWS that this shooter is
1) outsourced 2) may not be the one covering the day 3) may not be using the same techniques as shown in the demo however, these companies continue to use this work as a means to attain clients, whether or not this is an accurate representation of sale, is a grey line as to me, it isnt.. but there is no way of proving this... in turn the client makes a misinformed decision in turn affecting the quality of teh product and the opinion of video services as a whole |
