I need your expert opinion. at DVinfo.net
Old January 16th, 2007, 05:55 PM   #1
Hi guys I have just joined the forum and would like to get your opinion.
I just bought my XHA1 and VERY VERY excieted.
what you guys think of doing wedding shoots in DV24F or I should do them in Dv 60i?
Please keep in mind that I use Vegas editing software. so help me here!!
Matthew
Matthew Amirkhani is offline   Reply With Quote
Old January 16th, 2007, 06:03 PM   #2
Moved to Weddings and Events. The decision between 60i and 24p is strictly one of personal aesthetics, but perhaps this forum will have some constructive input for you.
Old January 16th, 2007, 07:49 PM   #3
considering the virtual no loss res in frame mode, id shoot 24f
Peter Jefferson is offline   Reply With Quote
Old January 17th, 2007, 07:34 AM   #4
Still Motion
Isn't 60i much better for slow motion compared to 24p or 24F?
Not only that, I could maybe pick out two or three couples I have worked with how might be able to see a difference between 24p and 60i, so I find it hard to think it would be an attractive feature overall.
Patrick Moreau is offline   Reply With Quote
Old January 17th, 2007, 04:00 PM   #5
hey pat, it depends on how its done... im on remote but il explin more wen i get back
Old January 17th, 2007, 11:13 PM   #6
You could always shoot 60i and convert it to 24p in post. For the shots you want as slow motio, use the 60i and slow it down by 60% (to 40% speed) so that it matches the rest of your 24p footage.
Andrew Ott is offline   Reply With Quote
Old January 18th, 2007, 11:58 AM   #7
Excellent point Andrew,
I think I 'll just do that since I don't want any motion blur or headaches!!
Matthew
Old January 18th, 2007, 02:52 PM   #8
Images: 5
what method do you use to convert the 60i stuff to 24p?
Ethan Cooper is offline   Reply With Quote
Old January 18th, 2007, 05:11 PM   #9
Hi Ethan,
I myself use Sony Vegas 6 & 7.
Old January 18th, 2007, 11:17 PM   #10
Vegas wont have an issue with any format you throw at it..
as for the camera.. shooting in 60i for conversion may not be the best opiton.. IMP shooting native alows the cam to do al teh converting fo ryou, in turn offering a better interpolation of frames (considering 24/5F is a frame mode from interlaced source) Use the Digic processor dude.. it kicks ass...
as for slowmotion, with vegas, id say shoot 24/5f at a faster shutter, WITH sharpness boosted one or 2 levels in cam.. then when u run it through vegas, do it in EVEN increments.. i do it in lots of 25%, render with supersample, then reimport then do it again (depending on how fast i want the footage.. most of the time though, i dont need to do this unless im bring somethign down to less than 33% or something..
Vegas interpolates FRAMES better than it interpolates fields IMO.. so your slomo should look cleaner and sharper from a progressive source.
Also, Dont run slowmotion if you intned on blowing out certain colours.. do teh filtering, THEN apply the slow mo.. same with reframing a composition..If vegas sees a peak blowing out over 255 peak, then the slow motin will flicker and stutter and look like rubbish.. keep levelsa low and dont forget to tweak your in cam gamma settings.. tehy can offer wider dynamic range which help tenfold in post..
