Cannot write back to MiniDV.Pls help! at DVinfo.net
Old May 17th, 2006, 07:53 AM   #1
guys,I wanted to record some edited footage from AP 2.0 to VX2100 in order to watch it on tv.the process of recording goes well when I "export to tape",but there is nothing on the tape afterwards.Its blank!whats the matter?
Thank you
Denis Potasnikov is offline   Reply With Quote
Old May 17th, 2006, 08:55 PM   #2
Did you hit record on the camera after it started to playback or before? If not, there's your problem.
Eric Hansen
Eric Hansen is offline   Reply With Quote
Old May 17th, 2006, 09:07 PM   #3
Sponsor: JET DV
Other possibilities: The tape is write-protected. There's a menu option on the camera that needs to be changed to get DV-IN instead of DV-OUT.
Edward Troxel is offline   Reply
