Sennheiser Wireless Microphone ew112-p
Is this model (i.e without the 'G2') still worth a buy for groom mic'ing purposes.
What's the difference between the G2 and non-G2 models? Thanks |
channels, battery life, and size
The freq response of the mic head itself (ME4 <cardoid> or ME2 <Omni> ) is identical, The SN ratios is almost identical to the transmitters and recievers when using XLR. The major MAJOR difference is baterry life, the G1 http://www.studio-d.com.au/images/mic.jpg is what i use as well as a G2, (I dont have this on file) G1, Battery Life 90 minutes with Rechargable NiMh 8.2v G2 Battery Life 6 hours with AA 2500Nmh G1 Range - 150 metres straight line, 75 metres walls, trees G2 Range - 100 metres straght line 50 metres walls etc G1 Screw in antenna, not very flexible G2 Fixed antenna very flexible G1 channel - 360 (from memory) G2 channel - 4 Banks of 360 (total 1440 channels) G2 has a backlit LCD monitor which allows u to eailymonitor, while the G1, has an LCD, but not as "info packed" G2 also has a seek blank channel function, G1 doent have this, BUT im yet to ever need this anyway.. (ive run 6 mics without a problem, all on seperate channels G1, much more robust and looks like a transmitter G1, Looks weak, but it quite sturdy. Not as the G1 though. Looks like a pager |
Thanks Peter, that's excellent information, just what I was after
yeah the screw on antenna's suck. i've lost one already and its a $12.50 replacement with sennheiser. not too bad.
also, the g1 run off the 9 volt. where did you get the nimh 9 volt style batteries? Yooch |
#5 |
hey Yoochul
the 9v style 8.2v nimh was purchased from Jaycar here in aus, but basically any electronic hobbyist store will stock them. U really have to watch the heat on these (ie leaving them in the boot of the car) as they have the tendency to split. 9v recharchables should be available by now as well though.. with these rechargables, u should get about 90minutes air time, with good alkalines (Energizer, Duracell) u should be able to squeeze another 45minutes out of them |
#6 |
Thank-god I searched and just read this thread, I was about to buy a G1 system off eBay. That battery life is pants...and with a 9v! Sod that I'll wait for something else to come along.
Oh, just a question while I'm here..for anyone in the UK could you please recommend any sites or stores which sell any of the Audio Technica bodypack systems? I've been searching for ages and all I seem to get are the handheld mic and rackmount versions. Arggghh.... |
#7 | |
And personally, I'd never use something that requires a pricey 9volt battery. Because they're so expensive, it's tempting to keep reusing them and you really don't know when they'll fail. AA are about 40 cents each, provide long life and are disposable. Just load your gear with fresh ones before each shoot and chuck 'em after. Or put save 'em for your nose hair trimmer. :) |
#8 |
I have the ew 100 G2 model Lav and I love it. When I film concerts I use it to tap the board, and even at weddings. I have no problems with it and that lav has been through hell.
