My first wedding shoot shot with a vx2000 at DVinfo.net
Old May 2nd, 2006, 01:20 PM   #1
Hello,
This is my first wedding shoot. I'm looking for any pointers that will help in my next shoot. http://www.earthquakeproductions.net/wedding/flash.html
Btw, the above link is a flash stream and requires a high speed connecting to view.
Troy
Troy Davis is offline   Reply With Quote
Old May 2nd, 2006, 01:38 PM   #2
Looks nice
Troy, the clarity on that flash compression is great. How big is that file? What did you use to make the player?
I really liked the bridal walk angle you had. I think you captured a lot of stuff, some really great footage. Was this thier final, or a snippet. Did you have to work around a photographer?
If I had one simple opinion, it would be the affects on the end were a little heavy, the heart, the sun beam etc, but that's up to your client, hehe.
I think the clarity of that video is great. If that was your first shoot, you did great.
Old May 2nd, 2006, 01:49 PM   #3
Steven,
The flash flv is pretty large (well over 10 meg I think) and the player was made using Flash 8 medium quality.The video was edited in Vegas 6 and then imported into Flash. This was just a snippet and the final is due in June. And yes, I did have to work around the photographer, but he was very accomodating. I'm glad you pointed out the sunbeam at the end. I only used this to cover up a large water spot I had on the lens from the water shot :-) I thought the heart trans was a little corny and won't be using it in the final. Thanks for you input.
Old May 2nd, 2006, 03:36 PM   #4
Troy:
Great shots.
Did you shoot in 16:9 or add letterbox in post ?
Way to go. Love my VX2000, and you really show what it can do !!
Chris J. Barcellos
Old May 2nd, 2006, 05:54 PM   #5
Originally Posted by Chris Barcellos
Troy:
Great shots.
Thanks Chris. I shot in 16:9 and it worked out pretty good in post.
Old May 3rd, 2006, 04:09 AM   #6
so, you added the letter box in post? So you needed to think about that when composing your shots?
Simon Antoniou is offline   Reply With Quote
Old May 3rd, 2006, 07:34 AM   #7
Yes, I shot in 16:9 mode, so the letter box frame was in the camera. In post the letter box effect was automatically there. I hope this makes sense.
Old May 3rd, 2006, 11:16 AM   #8
Simon:
VX2000 and VX2100 and PD 150 and 170, can select 16:9 in camera. It does show up, then, as 16:9 in editing. When I first bought my VX2K, there was a lot of talk that the 16:9 selection created some issues with respect to resolution. In fact, recommendation by some was to shoot 4:3, and place a matte on your LCD finder, or to insert a letterbox from a .jpg file using memory mix. I've done it that way for many years. But you can see Troy got some pretty nice images, and since I am now mixing DV SD from my FX1 in 16:9, I will probably be using the built in 16:9 mode.
Chris J. Barcellos
Old May 3rd, 2006, 02:59 PM   #9
Thanks for the info..
It’s just these letterbox issues confuse me as when I watch films on my widescreen TV, sometimes its letterboxed sometimes its not, new and old films.
When I shoot, I do want the letterbox look. But even if the camera shoots in 16:9 the letterbox is not there and I need to put tape over the monitor to compose the shots.
Is there a different way or do some cameras have the letterbox automatically?
Old May 3rd, 2006, 03:57 PM   #10
Simon:
Yes, there are cameras that are native 16:9. All of Sony's new HDV cameras shoot native 16:9HDV and SD, with provisions to shoot 4:3 as an option.
The real confusion with DV in my mind is that whether it is filmed in 4:3 or 16:9 nominally, it still comes in the same 720 x 480 package, from what I understand. I had this drilled into me by one of the tech guys on this forum. Because of that, I always felt you can't go wrong by shooting in 4:3 and adding a letter box matte. You lose the bottom and top pixels, but it would seem to me you would loose it anyway by shooting in 16:9 mode on the Sonys. Now, as I understand it, the native 16:9 s have more pixels, but that would mean it still gets squeezed back into the 720 x 480 nominal package. If any of this makes sense to anybody, maybe they can pick up the technical explanation from there.
Chris J. Barcellos
