Iriver or Zen Creative at DVinfo.net
Old April 10th, 2006, 09:31 AM   #1
I am looking at getting an Iriver for capturing voice but there was also this Zen Creative that does some of the same things that the Iriver does. I just wanted to know if there is something special about the Iriver? That Maybe this Zen Creative does not do. Thanks for any help
Zen
http://www.bhphotovideo.com/bnh/cont...ist&sku=388107
Adam Thomsen is offline   Reply With Quote
Old April 10th, 2006, 09:48 AM   #2
You might want to follow this thread:
http://www.dvinfo.net/conf/showthread.php?t=55496
Scroll down to post #8. Should answer your question.....and then some.....
Edward Slonaker
El Pilon Productions
San Patricio, Texas
www.elpilon.com
Edward Slonaker is offline   Reply With Quote
Old April 10th, 2006, 02:10 PM   #3
Hey Adam,
How's it going? I don't think the Zen has a preamp for external mics like the Irivers do. If you're looking at Irivers, you also need to make sure they're the right make. Someone correct me if I'm wrong, but I believe all the newer models lack the preamp feature. You can still find Irivers that will work for you out there for sale, usually used or refurbished.
Pat
Pat Handley is offline   Reply With Quote
Old April 10th, 2006, 03:08 PM   #4
What Pat said is right. The Zen Creative does not have the necessary pre amp. You will need a powered microphone with the Zen. You can use the iriver 700, 800, or 900 series. They do not require a powered microphone.
Mike
Mike F Smith is offline   Reply With Quote
Old April 11th, 2006, 09:18 AM   #5
Hey Thanks Pat! I didn’t want to bother you guys about this figured you guys have seen enough of me. Did you get the Hutch wedding finished? I am excited to see it put together. I think that the Iriver is the best way to go. I will just get one off eBay.Which do youthink would be bette the 1gig or the 256MB?
Old April 11th, 2006, 09:43 AM   #6
I was able to get the 1GB IFP-899 model for $99 from some place out of Florida on eBay. It's one of those "factory refit's" but it works perfectly, came just as if it was new, and I got the 3-yr warranty with it for another ten bucks.
Edward Slonaker
San Patricio, Texas
www.elpilon.com
Old April 11th, 2006, 09:53 AM   #7
iriver
Adam,
The 1GB may be more than you need, but if you can get it for $99, why not? A 256 should get you about 3.5 hours of record time, the 512 will get around 7 hours, and the 1GB will be double that. The 256 holds plenty for a groom mic, we usually use the 512's for reception coverage.
I'm rendering the Hutch wedding this afternoon, I'll give you a call when it's burnt. The welcome mat is always out for you!
See you soon,
Pat
Old April 11th, 2006, 10:28 AM   #8
if you are lucky enough to find any model of iriver ifp-7xx or 8xx , just buy it.
it is extremely difficult to find them now, especially models with more than 256Mb.
Old April 14th, 2006, 08:24 AM   #9
Check out overstock.com
http://overstock.com/cgi-bin/d2.cgi?....x=0&IMAGE.y=0
They have some refurbished iRivers for a decent price.
Peter Chung is offline   Reply With Quote
Old April 14th, 2006, 08:34 AM   #10
thanks , i will order 2 asap.
Old April 19th, 2006, 03:20 PM   #11
best mics for irivers...
Just picked up a couple of IRiver IFP's, a 1gb 899 and a 512mb 895. I know I've read some about the giant squid mics, but are these the best to use with the IRiver models I mentioned? If so, where's a good place to pick up a couple of those?
Vincent Croce is offline   Reply With Quote
Old April 19th, 2006, 03:45 PM   #12
http://www.giant-squid-audio-lab.com/gs/gs-mono1.htm
This is the microphone you're looking for (scroll down towards the middle of the page). It's specifically designed so you can record mono on the iRivers. If you try any other mic, you'll only be able to record in "stereo" mode. AND, they're good mics!
Edward Slonaker
San Patricio, Texas
www.elpilon.com
Old April 19th, 2006, 04:37 PM   #13
thanks, Ed
I'll be using the two IRivers w/giant squids plus my Azden 200ULH (dual channel) wireless system going to one PD170 on tripod, plus the shotgun on the second PD170 roving--you can never have too much audio! One more question--how long of a cord would you think would be just right--the 3 footer? Also, do I need the right angle adapters for the IRiver/squid setups?
Old April 19th, 2006, 08:01 PM   #14
There are many schools of thought on the length. Some like it short so you don't ever have to loop the cord, some like it long "just in case..." I went with the 3-footer. Seems like a nice size. And, yes, I got the right-angle plug, but I honestly am not sure why. The standard, straight plugs fit in the iRiver just fine. I read on another thread where someone recommended it so, there you go....
Have fun!
Edward Slonaker
San Patricio, Texas
www.elpilon.com
Old April 19th, 2006, 09:41 PM   #15
Thanks again, Ed. I'm curious to hear just how good the IRiver/squid combo sounds-hard to believe such inexpensive gear can give me the quality so many on this forum have talked about.
