XLH1 + Sameday Edit sample - Page 2 at DVinfo.net
Old February 13th, 2006, 03:59 PM   #16
We charge quite a bit more for an HD wedding video, so we only supply one camera man at this time. However for those wanting a SD project, I will use the XLH1 and will have the other guys shoot on the XL2. I have yet to combine the two in the same video, but I'm sure it'll be okay.
Doug, when you say panning around with the HDV in the SD timeline, do you mean importing the HDV file, full res., and then moving it with keyframes? If so..yes, I've tried it, but I don't like how the movement looks.
Lowell Oswald is offline   Reply With Quote
Old February 13th, 2006, 05:59 PM   #17
yes Lowell I do mean that, but you would need necessarily to have movement in the frame, I was also thinking of the advantages of being able to go from say a medium shot to a close-up etc in post.
Doug Bennett is offline   Reply With Quote
Old February 14th, 2006, 01:09 AM   #18
Doug, you're a genius! I didn't even think about that..it's so simple too! that would definately add more to this video. Thanks, I'll try to get another copy posted soon with some of the changes that have been suggested.
Old February 14th, 2006, 02:39 AM   #19
"We charge quite a bit more for an HD wedding video, "
good boy.... Im glad youre charging appropriately!!!!!
Peter Jefferson is offline   Reply With Quote
Old February 14th, 2006, 07:05 PM   #20
so it really is that simple to do that Lowell. That is good news
Old May 22nd, 2006, 11:15 AM   #21
Beautiful!
Hey Man, you really did excellent job, especialy same day edit, t is very nice.
I have couple questions, what frrame rate did you use? I just purchased XL -H1 and would love to make video's like this, Is this in HD mode? or SD?
Any Info will be helpful,
Thank you in advance
Nerses Papoyan is offline   Reply With Quote
Old May 30th, 2006, 12:32 PM   #22
hey, Lowell and I work together on videos and what not, he must not have seen the post, but anyway, he filmed it in 60i in HD mode and down-converted it for the sameday edit. We use 60i because you can get much higher quality slow-motion with it.
Eric Hansen
www.ehansenproductions.com
Eric Hansen is offline   Reply
