#16 |
Re: USB flash drives 16gb
I never would have expected there would be that much variance between them.
When I was trying to decide which flash drive to buy I was surprised to see the number complaints in the lesser brands like AData. Problems like it wouldn't reformat, extremely slow, to failure after a month. I decided to spend the extra for SanDisk. |
#17 |
[Nigel]>It's not the PCs that have a stupid 4GB cap it's only if you use the FAT32 file system on the flash drive that files are limited to 4GB. If you format them as exFAT or NTFS or ext3 or HFS+ then there is no 4GB limit.
I’ve tried EXFAT and have had quite a few issues with mounting on a Mac. From these posts it hit me that maybe I was using a bad flash drive. The problem, though, with EXFAT is that TVs can’t play them, from what I understand. [Nigel]> Blu-ray can do 1080p@24fps but TBH progressive/interlaced don't really have any meaning with digital displays as 1080i@50i is effectively 1080p@25fps & 1080i@60fps is 1080p@30fps. Whatever Blu-ray has at many times the resolution of DVD & looks enormously better especially on a modern large screen TV. I trust you Nigel. Sounds like I need to revisit Blu-Ray. |
#18 |
So if exFat cannot be played on tv's usb port , assuming that, then what USB format type will allow 4K content to be watched as 4K resolution ( not watered down 1080 ) ? Without glitches/skipping frames/pausing
issues. Just a clean 2 hour uninterrupted 4K playback on a stick, no boxes or wires attached. |
#19 |
I think whether something is readable can vary widely. My tv for example is very limited it will only play one format mpeg2 and maybe only up to 720p while my Sony Bluray player with usb port can play almost everything mpeg2, mp4, h264, mkv etc
As far as exfat mac and pc should read it. |
#20 |
My TV can play USB formatted to NTFS and not exFat - tried the latter and it wouldn't recognise it. However it can play 4K uninterrupted as long as I don't see the bitrate too high. I find 60mbps works well giving smooth playback without any judder. I use this for the occasional same day edits, where I do a rough cut of the Ceremony and playback in the evening. Shown on my 55" 4K TV screen I loan for the evening, it plays a 15 min on a loop over 4 hours without hiccups. I've shown longer videos too - not for Weddings.
#21 | |
#22 |
If you want 100% TV compatibility and large file sizes greater than 4GB then you need to be looking at a HDMI media player such as this. I take one to client's homes to demo my stuff - simply plugs into the HDMI port of a TV and plays back from a selection of memory cards - £22
As far as I can tell It's the same as the TakyBox solution only without the nice looking menu Cyclone 1080p Micro 2 |
#23 | |
Thanks. |
