#16 |
Re: Best shooting technique for hand held video
It has nothing to do about "how I feel", it's just common sense to me that a steadycam is no substitute or replacement for handheld shooting, there is a hugh difference in handholding the camera and actually operating it manually in a run and gun situation compared to using it on a steadicam or gimbal where you are mainly controlling the gimbal but not the camera.
#17 | |
#18 | |
Going back to the original question. If using a shoulder rig, to disguise camera wobble you have got to have either the camera image in motion (panning, zooming included) or have the subjects themselves moving. Or both for that matter. Camera wobble only becomes most noticeable when you're trying to hold the camera still on non moving subjects. That is the draw back of shooting handheld. Perhaps a minor one depending on what you shoot. If stable footage is important in such cases, then you need to think about either some form of stabiliser (external or internal) or use a monopod. Though none of these options are handheld, they do allow you more freedom when shooting run n gun than a tripod. |
#19 | |
#20 | |
I appreciate that handheld has some advantages over the gimbal, but some disadvantages too. That said, I can adjust focus, I have placed a ND filter on and off, plus made some minor setting changes without turning off the gimbal. I have footage of that if you feel proof is needed. It is true some gimbals go haywire or so I've heard if you dare touch the camera. Perhaps because I have some cable attached to the hotshoe, mine does respond well and I can even turn on the camera once the gimbal is activated if I have forgotten to do so before hand. Tilting the screen is also possible. I have to be careful using the wheels, but basic button presses are possible. I have adjusted ISO on the fly and exposure compensation, switched on and off peaking. Again, without switching off the gimbal. So I have focus control, exposure control, ISO control, peaking control; all without turning off the gimbal. Can't adjust volume though, changing menu settings would be tricky. So yes, I'm pretty restricted there compared to handheld. When I get a moment, I shall have to upload a video demonstrating this. I suppose from my perspective, I use the monopod in the way you use handheld, so for me the difference is rather between the monopod and gimbal as opposed to handheld and stabiliser for you. In that I can see clear differences as you describe. Before the gimbal however, I only ever handheld the camera for walking back down the confetti line and for moving around the dance footage; in those cases, I have found the gimbal has replaced such shots when possible. |
#21 | |
#22 | |
#23 |
I"m only saying as you make it sound it's the same, it isn't.
#24 | |
My original post was a reaction to watching the live feed from a cameraman following a group during a televised golf tournament. He was using a large shoulder mount camera and kept the camera in continuous motion (slight pans and zooms) so any wobble/shake was not noticeable. That prompted the question as to whether there were additional techniques I could employ in my shooting. I'm pretty much a newbie when it comes to serious video, so the collective wisdom of the forum is very much appreciated. |
#25 | |
#26 |
I have a ls300 and use the 12-35mm lens on it so I can tell you what I have done to stabilize handheld shooting, I got a small springloaded monopod which was too long but that I cut to custom length and I have a tactical vest from lowepro where this monopod is attached to, you can ofcourse also suspend it from a belt but I have found that you get a bit more unwanted motion when you move. The monopod takes all the weight out of my hands and the spring inside the monopod helps keeping it more stable. It's not perfect but I find my handheld footage pretty stable.
#27 |
Steve, Noa
Thank you for your suggestions. Regards, Luke |
#28 |
If you have a shoulder mount then the sprung rod is brilliant .. I had one for my Sony EA-50's and being very front heavy, the rod and waist belt helped a LOT ...definitely worth getting. Most prosumer cameras or cameras that go onto a shoulder mount are very badly balanced ..I think the only exception is the JVC 700 or 800 series where if you put the camera on your shoulder it's neither front or back heavy which is more important to achieve if you are shooting from the shoulder. Just for interest I got my sprung rod from Camtree in India for the mere $60 .... It does need a bit of cleaning up so the rod pieces slide smoothly however the actual belt was useless so I just grabbed a LowePro fanny bag and used the belt from that and stitched a pocket in that. On my Panny's I'm currently using just a very simple piece of aluminium flat bar under the camera with a handle each side which gives me a two handed grip but for long winded processionals my arms get tired so I would like a mini support rod that is sprung to keep it stable. Where did you find a monopod section that was sprung Noa???
#29 |
I have a shoulder mount but stopped using it because it was counter productive. While it did a great job distributing weight back to my shoulder making it easier to hold, the wide handles in the front acted like levers that multiplied the camera's yaw. Like putting your camera on the end of a sea saw a little motion on one end creates a lot on the other end.
I've found monopod a good compromise. Like others have said the inability to touch your camera on a gimbal/steady cam and complexity of setup and operation make it a challenge to use. I've found that it's not hard to hold a camera until you strap on all manner of accessory and when a 5 minute speech turns into 20 minutes. |
#30 |
I raise my monopod all the time :) Very useful on multiple occasions when there are too many people!
